The joys of tearing down a 5 speed box on a bike that has probably been ridden shall we say aggressively in a past life?The shift return spring is simple enough and cheap to replace which is a must once the cover is off.The selector dog faces will probably have signs of wear to the point of edges broken or worn off.I would replace the trust washer set with this updateInspect all the case bearings and while the gear box is out replace the U joint and U joint carrier bearing in the swing arm
I have the transmission out of my '83 1000SP for a clutch replacement. 41,000 on the bike, there's no problems with the transmission shifting, no slop, U-joints and carrier bearing are all in good shape.Does it make sense on this bike to remove the rear transmission cover just for a pre-emptive replacement of the shift spring? Will I knock something else out of whack doing it, or is it pretty simple to remove the rear cover with the tranny on the bench and replace the spring?Thanks for any opinions.Lannis
I'd go ahead and replace it. My spring broke on my 96 Cali. The hardest part of the job is getting the box out.
I would prob give yours seals and o rings while it is out, only change return spring if physically damaged.
Sometimes good original parts can be better than new ones (different cheaper alloys etc) that you might buy today. My water-well guy told me that my 20-year-old "Red Jacket" pump would last longer, starting today, than any new replacement he could sell me, and he recommended leaving it alone ... Lannis
