What bike?
Here is what I have done on quite a few occasions with painted metal fenders.Mark the shape you want to cut on the fender. Tape off the saved part of the fender with vinyl electrical tape, several overlapping layers back up on the fender. This is like making a stick on template. Get a Dremel or equivalent with thin abrasive metal cutting blades and carefully begin cutting. Just score the fender next to the tape, and then repeat making the cut a little deeper each time. Make sure you leave the edges of the fender to cut all the way through till last, as this will keep it in tact till the end.Important, the reason I use the vinyl electrical tape it to gage heat. The abrasive wheel will generate heat and damage the paint. Go slow, very slow so the tape doesn't start to melt. That will prevent damaging the paint. Next use fine sand paper to smooth the cut edge being careful not to get onto the outer paint. Once smoothed, remove the tape and touchup the exposed metal edge from the cut with a similar paint.
Thanks for the replies guys, very helpful.I would have thought a Dremel was the tool for the job, but GuzzistJohn suggests a pneumatic grinder and Orange Guzzi suggests a SkilSaw, which seem to me much more powerful and, erm, brutal. Am I just being a wuss?- Pasta
Chainsaw it is, then!
