I am into it. The allen bolt above the axle is looking like the problem. I hear the "air escaping noise" when I pump the slider. All the oil must have leaked out. Friend above wrote about "slug" on the inside needing to be lined up w/pin on re-installing said screw. Not sure how that's to be done as it is out of view. Ray Charles method?? The exploded parts diagram I have is not detailed enough to show this.
I just pulled my axle (03 EV forks, but apparently the same construction) for another reason. The bolt is an 8mm allen head. I'm guessing it has a 10mm shaft. It might be a candidate for rattle gunning out, if you didn't knock it loose in the impact. Mine is reluctant to crack loose.An aluminum or copper banjo washer should be making the seal. This looks like a good place to try one of those sealing washers with the rubberized center.
One problem is that the hex bolt at the top of the fork tube just below the adjuster, unscrews a couple of turns then stops with stubborn resistance. I understand it should come all the way out to pull up the inner assembly to add oil. I hate to apply more force. Could this be a sign of damage to the inner assembly?
More damage than I hoped for (but I didn't wreck).I have taken apart the damaged (right) fork assy. Turns out the aluminum base block, which threads into the bottom end of the steel tube (and houses a piston & spring) and which fixes the bottom end of spring assy (with the base bolt above the axle), parted when threads stripped out. The ride back thoroughly mashed the plastic "drift" or "pad", also located at bottom of slider. Curtis Harper tells me I need to buy the whole compression assy.(part # 29525360), as the aluminum base block and piston are not sold separately. That's hundreds of the hard earned.http://wildguzzi.com/forum/Smileys/default/weiner.gif
