Hello,New poster; nice forum! I'm pondering buying my second carb Sport--first one was in late 1994, sold 1997. It's one of two or three bikes of 13 owned that really stuck with me. To go with the full Staintune system, Raceco's Manfred recommended Mikuni HSR42s, which had just become available. It took a lot of faffing to install, but, they worked well, though I never did dyno comparisons. Has anyone ever done a dyno comparison between these carbs? If there aren't enough of a gain, my older, more objective self can't see spending $$ on Keihins or HSRs. I might expect more area under the curves--but how much more?Thanks-Kristian
I'm running Keihin FCR41s with a K&N filter in the stock airbox, and full Staintune.Dyno is in the low 80s with a much smoother curve than it had with the Dellortos and Marsee crossover.Nice improvement in power, but more noticeably the driveability improved, the fuel economy improved, and the effort required to twist the throttle was greatly reduced.
Unless you are building for top end power and blowing thousands of dollars on cam, carbs, exhaust, heads, etc- , you don't need $1000 carbs. Spend $60 and jet the stock dellortos correctly and enjoy the bike. ed
There is also a smaller(larger?) diameter throttle for better action to WFO, otherwise you need 2 hand fulls.
Unless you are building for top end power and blowing thousands of dollars on cam, carbs, exhaust, heads, etc- , you don't need $1000 carbs. ed
The Keihins work well- they're a more modern design than the PHF's. Roller bearings on the slides, cammed slide action etc. But with a handful of jets, adjustment of slide springs and the right throttle cam, you can make the PHF's work well.
SnipThey will set them up for you ( altitude, exhaust, engine mods etc. ) Save you the cost of some dyno time.
I've fitted a set of Mikuni HSR42's to my V1100 sport engine lemans 4. Jetting was done following advice from the V11 lemans forum for the Mikunis snip
SnipGiven my '85 LM1000 with 11:1 compression, RHC ported heads, Web 86b cam and BUB exhaust making 68 rwhp with a lot of room for improvement and your engine being bigger, taking into account the throttle response and sensitivity I'd think you'd do well to stay with 40's. Just my $.02.
If a true 11:1, have you considered knocking that back to 10:1? There are good reports--from Germany's Dynotec, one of the world's best Guzzi tuning shops--that 10:1 is a real limit on these 2V Guzzis. High piston crowns + poor gas apparently cause all sorts of complicated problems...Best,Kristian
I followed his recommendations and but used some velocity stacks and foam air socks. the Air box was removed.I also used a set of the plastic air intake manifolds from Stein Dinse.
Totally different setup I know but I have Keihin FCR41s on my Ducati 900 Monster with no airbox.
When I set them up at the dyno, sock filters over the (stock) stacks cost me 5hp at the top end but no real change in midrange - the K&N stacks with filter fitting provision (and K&N filter) work much better for me.
