Set it up at TDC, doesn't matter which side, and look at the edge of the flywheel on that side. You'll see an arrow stamped into it. That lines up with the little cast in divot in the crankcase that is in line with the centreline of the bore on that side.
The divot.... where is it and please describe a little more.
Ok... so the arrow on the flywheel aligns with this arrow and the D will then be on the right where the peep hole usually is, correct?
Do you have a photo of the dot Charlie?
Yes, after I write you I saw in in my Haynes manual. What does the TCD mark look like? I see nothing on the face, is there another on the edge?
Same as the arrow, yes?
