Did you happen to put fuel in it just after picking up or was it fueled up just before you picked it up. What you describe sounds like a bit of water in the bottom of one of the float bowls. The idle jet is normally higher in the bowl than the main jet. At idle or cruise the idle jet is supplying a lot of the fuel. At full throttle the main jet is supplying almost all of the fuel. If your carbs have a drain on the bottom of the bowl I would drain the carb into a glass jar and look for signs of water in the fuel. It will be in the bottom of the jar. Even if no water appears present I would drain and take for a ride. Depending on the outcome determines the next step which may be a drain of the tank.Steve
If it is water, which is only a suggestion, what the reason for having to roll the throttle back is to stop the vacuum trying to pull a water/fuel mix up through the main jet. What I have never been able to work out is why the water does not just get sucked through the jet and clear itself. It appears to just block the jet. If I read the description properly ohiorider just said he rolled the throttle back not the revs dropped.Of course water is just one suggestion. I hope ohiorider lets us know the final outcome as I have often seen a question asked and heaps of excellent suggestions given with no final outcome. I would not have thought of a leaking diaphragm but can see how it would cause the issue by causing an over rich mixture.Steve
PS - for a bunch of Guzzi guys, sounds like there's considerable background in BMW Airheads. Love it! And thanks to all of you for your comments and suggestions.
Guzzi guys are motorcycle guys. Many if not most of us have had airheads, too.
OhioriderDid you get the problem on your BMW sorted? I have not been able to sleep at night wondering what the fault was. Steve
