I used the standard 5 ohm black dyna coils on my LMII and am very pleased. Plenty of room for mounting compared to the old oil cans. Had to fab a simple bracket with some flat stock . The mini's are more $ if I remember right and are 3 ohm. I'm pretty sure all the lemans bikes have 5 ohm resistor caps anyhow so either coil will be fine.
I know they sometimes add resistors in series with the coil but I can't see the sense in that, but as I mentioned I'm no coil expert.
Coils with the lowest primary resistance produce the hottest spark.
It makes sense to me that igniting the mixture with a hotter spark 'gets the ball rolling' quicker. Like the difference between using one stick of dynamite or two.
- the coil's ability to spark under pressure.
