Interesting,I had never heard of the steering stem problem.
Do Moto Guzzis rock in the opposite direction when south of the equator?
I call BS on the steering stem "problem" as well. If that were the case, there would be binding you could feel in the bearings when the steering stem is tightened down. My 85 has the 16 incher, and it handles beautifully, but it does like 35-37 psi in the front tire. My 85 LeMans holds a line in a high speed sweeper, like no other bike I have ever ridden .The chassis on the bike is very nice, but where it really rocks, is the big valve motor!Rick.
Are we allowed to look at a LeMan w xs650 mufflers? Isn't that some sort of brand blasphemy and indescribable bad taste?.......
Yep, those XS650 cans just look wrong. Maybe someone should introduce the bike to some up swept Lafranconis.
Wirespokes, Can you please post more information regarding the showa dampers? That sounds very interesting!Rick.
I got a set, used off of ebay, complete forks with dampers inside from a '90s VFR for less than a hundred bucks. I was told only very minor mods to the damper are needed to make them fit an earlier LeMans or T3 - like cutting them a little shorter and rethreading the tops. I don't have access to my data at the moment, so that's the best I can give you. It's possible they'll fit the LM 1000 with less work - perhaps they're not too long and don't need cutting down. They're supposed to be a big improvement over any of the normal cartridges for these forks.
