How about using silver solder on the outside ?
Been there, done that.I had a 1994 California 1100 that leaked in the same spot, on the left side. Ate up the floorboard rubber too.I believe there is a lot of flexing and stress from the tank mount right there.I tried to solder it. Did not hold.I tried solder and JB Weld. Did not hold.I tried silver bearing solder and JB Weld. Did not hold.I tried silver bearing solder, a metal plate, and tank sealant (POR-15). That held.I got a good deal on a replacement tank and installed that, so I don't know if the soldered plate with sealant was a good solution. I do know that simply putting solder on it is worthless.
True silver solder might be good.
I do not want to destroy the finish because the second owner had some pinstriping done to honor his friend , who only enjoyed the bike for the first year . Side-covers and fairing to match . The inside of the tank looks spotless from what I can see , so I hesitate to use some kind of coating on the inside .How about using silver solder on the outside ?
I thought the whole point was to save the pin striping in honour of a friendI would line the tank with Caswel or get another tank and put it on the shelf.
Again, the Permatex epoxy stick has lasted me 20 years. You don't need much. Just make sure to degrease the area before applying. Then touch it up with a artist brush. As for tank lining the Caswell plating product will last though I would save it for the second step if needed.Pete
The silver solder I was thinking of is 96/4 . 96% Tin and 4% Silver ; melts about 450 F .I looked in the drawer and the flux had leaked inside the container and my silver solder has crystals on it , and the data sheet is mostly eaten up by acid . I used it last to join a handwheel to a piece of 1-1/2" d.o.m. for a collet closer on a lathe . It held , so there is a good chance that it would hold a 3" sheet-metal disc to a flat surface on the fuel tank , if properly prepared . The leak is tiny , so I was tempted to clean well on the outside and apply the solder , but the concern is cleaning well enough between the mount and the tank .My friend Mike is a good TIG welder . I'll run it by him .
Silver solder would be the way to go if you intended to repaint the tank. Otherwise the heat will just damage more of the paint. I didn't want to repaint my LeMans tank so I went with the Permatex. Besides the patch is covered by the seat. If it ever does fail you can just file it off and try something else.
If it is like mine, the leak is on the inside wall. Not near the outside. With care the outer paint should be safe.
