Leyroy, 75k? I assume you've replaced the cam tensioners by now yes?Taz, cam tensioners are the big thing. If not already upgraded to the hydraulic tensioners plan for that now if it's going to stay around.Idle jumpiness is typical on the rubbermounts, especially the BTs. Ironically the counterbalanced/solidmount motors on the last generation and new generation Softails are the smoothest at idle. The irony is that back in the Evo days the Softails were true vibrators.Anyway the FLH series is, as you already know, quite smooth underway and hides its weight surprisingly well.I tend to run stock exhausts and fueling without problems.
Replaced at 67000 miles.Worn but serviceable.
