I think you’re going to be disappointed with the treadlife. They’re a supermoto tire designed for sub 400lb bikes. They’re also bias ply. A friend mounted a set on his DRZ400SM. Not exactly a rocket ship at 35hp and about 350 pounds. He got 2,800 miles out of them.
Thanks for all the feedback.When I said I chose them, the bike is sitting on the Heidenau rubber right now.I don't have a problem with running bias tires, it's all there was until a few years ago, they have a more rounder profile which should be better on gravel than a flat radial. Also seem to be recommended for a cruiser which is really the sort of riding we will be doingChuck H, It's reassuring to hear that some Stelvio owners run the K60 Mtberio, the tires were so bad you sold the bike, why didn't you just change tires?Thanks for the warning about how slippery they are, I must say I'm surprised looking at the tread pattern, bear in mind I will be on K73 with smaller tread not the K60.Egschade, I was looking at the Pirellis, perhaps I made a mistake. I took Pirelli road tires off, they will be going back when I return, the smooth road pattern would be no good for gravel.I will report back at the end on June
Just a clarification; the K60's aren't remotely related to the K73's in terms of longevity. K60's last forever and are incredibly popular in the ADV community for their traction and tire life. I wouldn't bother swapping out the K73's if your trip is under 3,000 miles and it's mostly gravel. They should make it if you don't hammer on them and keep them at the higher end of the pressure range.
