How does the bike react when you close the throttle at 3,200rpm? Mine is a real helmet knocker when it suddenly goes stupid lean. Decelerating anywhere from 3,200 to 2,000rpm sucks. I'd load a new map to alleviate that issue alone.
I haven�t noticed that issue on mine but I haven�t paid no attention to it either. Next ride I will. Are you saying it decellerates to strong?
Ncdan, forgot you ask what mode. Seems to have stronger eng.braking in veloce, & less in touring but still an on & off condition in either mode
To me, it is not an abrupt decel issue. I'll call it engine braking, like a big truck, going down a hill, & the engine holds you back. Nothing wrong with that but when it turns on & off, that's where it is annoying -slowing you down as your @ 4000, 3500, 3250, then 3000 rpms then let's go (as if you pulled the clutch in) on my bike on a long downhill, around 3000 rpm engine braking would go on & off & on again, very weird on long downhill sweepers
While I never noticed this on my Cali 14 I spent almost all my time in 'Touring'.My guess though is that transition to almost a 'Coasting' type situation @ about 3,000 will be related to the RBW system cracking the throttle plate and adding more fuel at that point on a trailing throttle. I'd also hazard a guess that if you're running open pipes the effect will be exacerbated and the system in stock form may find it difficult to cope. Just one more reason not to be noisy. Nobody else wants to hear that shit anyway!Pete
Hey Pete, I owe you at least a beer, & a THANK YOU, for telling me (us) about the swing arm bearings, you alsodelete my account diagnosed my clutch switch from half way around the world. I don't know if loud pipes save anything but if you drive around so. CAL. .... like to lane split? Here's another part I came across, my bud knows how to solder I think I paid $35 US for 5 switches
Here is something else I've tried, for the 1400 fans. People complain about turbulence, I found these fork fangs. @ about $66.us .I had to make my own brackets. No turbulence
I wonder if something is different in the MGX than the others? My bike never leaves veloce mode and I've not noticed any of that decel stuff being talked about.
Ncdan, I just slapped this together to see if it worked, so I haven't taken the time to take it off ,& clean up the bracket. I like it. You need 4 bolts that fit your windshield bracket, & 4 bolts to attach the 2 fangs. Also need 4 spacers, about 5/8 inch to keep away from fork, the place I'm pointing at. I made these from some plastic or lexan I had here (approximately 3/8 thick,) but aluminum would work just fine if it's stiff enough. ( can cut & drill either material with wood tools) check the hole spacing with your actual partsm
The MGX has quite a different map to the Touring & Custom. May be the reason.
It does? I wonder why. How is it different?
Main fuel maps are different. Longer injection pulse widths. Ignition has marginally more advance. The ride mode torque demand maps are slightly different.I've not seen one in the flesh, but the stock pipes appear substantially longer in the pics. Most likely the reason.
Hmmnn...so how do those changes alter the riding experience? Sounds like lengthening the pulse widths and torque demand maps would make Veloce mode less abrupt? Is the ignition advance in an attempt to extract more power? Better mileage? This stuff is fascinating on a certain level.
I think one would need to ride an Audace or Touring back to back with the MGX to answer that. Specs on paper show a fully dressed MGX is 41 pounds heavier than an Audace. Similar or better performance with its lighter siblings was the likely reason for the extra fuel/more advance.
