You don't need a pump, but rather a reed valve to let the pressure out but no suck anything back in.
that's what pcv valves are supposed to do but they are usually disappointing in this particular application.
I'm now starting to wonder if it's coming from the front and the wind is pushing the oil around the sump making it appear to be the base gaskets when it's not.
Put a PCV on the breather and you might get oil aeration or foaming in the sump from these oil return lines, I think there is a good reason that Guzzi did not fit check valves to these bikesJohn
The crank pressure escapes up a pipe to the bottom of the frame at the head of the bike & into the frame. On the top of the frame and a little further forward is an M16 threaded hole to which a banjo attaches to a tube, that tube runs to the airbox on standard bike, on mine it just vents overboard.
If we think about that tube, it is in the airbox to see lower air pressure and help with the flow of air from the frame. I would find a way to re-attach it to the pods or some type of manifold to allow it to do it's job. Paul B
I do not buy this as the problem,
