Huzo, here is how I was able to match my buggered LH tb to my un buggered right side. Only need to pull the intake rubber couplings, and alum. injector manifolds. Trim and fit the gauge until a precision fit is achieved on your right un tampered side and then check angle with protractor. should be 4.5 to 4.8 degrees. you can than use it to adjust the LH side. I would then do the usual valve adjust and sync tb's and reset tps and self learners .http://wildguzzi.com/forum/index.php?topic=86663.0
Good idea Peter but an awful lot of variables could affect it. Including the accuracy of the construction of your duct (big time)I have no idea what accuracy is required to set these things up properly, but I'd be tempted to use the same duct and then swap the bodies overIf the accuracy requires a good flow measuring rig I would very much doubt that any of these idea would work in practice, again depends on the accuracy you are trying to achieveBack in my turbine days, I did a bit on gas measurement. When calibrating orifice plates the whole section has to be taken to the lab and if the plate is subsequently disturbed the cal is toast. It's an amazingly finicky affairJohn
The stop screws on both TB's are sealed. I imagine they are calibrated without the linkage rod installed. The bell crank will be set in the middle position and the linkage rod installed and locked. Both air bleeds will be closed when this procedure is carried out and then inblances caused by differential performance of the two cylinders will be compensated for by bell crank and air bleed.My guess
Huzo, I think your idea makes sense. I would second the idea of switching the two throttle bodies from side to side after you believe the calibration is done, as a check. I also wonder about the appropriate air flow rate for this kind of check. Do we know what rates are used in flow benches? It would not be hard to calculate an approximate flow rate in the motor when it is operating at cruising speed,* but I don't know if this is appropriate for your test setup. It could be that the sensitivity (and damping characteristics) of your measuring device change at different rates, or that the characteristics of the throttle bodies themselves are more critical at some flow rates than others.Good topic for speculation!Moto* I might calculate the volume of air containing a stoichiometrically correct amount of oxygen to combine with the fuel consumed at given mpg and speed, converted to units per second.
Huzo, your approach again makes sense.As for stoichiometry, I was thinking of calculating the gasoline consumed per unit of time like this, using some round numbers for an example. Suppose the bike gets 50 mpg at 60 mph, and we want to know what the rate of air flow must be.In one hour the motorcycle goes 60 miles, using 60/50 = 1.2 gallons of fuel. At 6.3 pounds per gallon, that's 7.56 pounds of gas per hour, or 3432 grams. Dividing by 3600 seconds per hour, the rate is about 0.95 grams of gasoline per second.Multiplying 0.95 times the stoichiometric ratio of 14.7 gives about 14.0 grams of air per second as the requirement. This calculation doesn't require an assumption about the efficiency of the cylinder filling.How you measure the flow rate of air in grams per second is another question. I don't know the answer to that, but do note that mass airflow sensors, as used in fuel injection, apparently do it. Maybe one of those could enter into a setup. Moto
Air flow is tricky, it's too hard to measure I was looking at my throttle bodies on the bench, I wanted to check if they were set roughly the same so i wandered out to the garden tap and filled both inlets with waterthey took about the same time to drain through the butterflies, close enough, water won't harm them.Use water flow under standard conditions, you can verify that by weight or volumeIt would be easy to make a simple test stand using a column of water that could be easily replicated across the globe.Huzo, I sent you a PM
Is this in response to post #14 KR..?
I'm more along the lines of..Fill the tank to the overflow and see how long it takes to empty.Not..Fill the tank to the overflow and see how much you get in a unit time.It's easier to measure time accurately than volume.
Gotta give credit where credit is due, Huzo's the one with the waterometer , I agree excellent Idea
Is it possible I have damaged something by pouring the water in while they are on the bike..?The engine won't go over TDC even with two people on it towed behind the car..!The back wheel just skids, should I force it..?
This will fix it
