You can put the center stand down to expand the spring then stick pennys between the coils and when you bring the stand back up it the spring will stay extended. Or just huff it off which is what I usually end up doing. There are other ways too which somebody will post soon.
What bike?
I take mine off the Norge every 20,000 k and I do it by leaving the spring/s on, and taking out the left hand bolt first.That lets the stand move up towards the engine, and relaxes the tension on the spring/s. The pivots appreciate the grease...Also, while you've got it off, clean it properly, and pre emptively improve the weld on the cross piece, because...Mine broke while I was on the way to Dover from London in 2014 and I nigh shat myself when I heard an unholy rattle coming from underneath the bike, I did the trip without one, (a right pain too I'll attest..)Also, if that weld let's go, on the cross piece as you're hauling it up on the stand, the whole shooting match is likely to go arse up! I put a slightly larger diameter piece of tube on mine with decent gauge.Just sayin'...
I prefer floorboards, too.Get the bike high enough that the center stand doesn't touch the ground when deployed.loosen the transmission through boltremove the two pivot boltsSwing and pull the stand backwards while levering down at the forward point.When reassembling, attach the springs to the lugs on both the stand and the bike. Use zip ties to hold them there. Once it's in place it will about hold itself.lever everything back up and pop in the pivot bolts.
Thanks for that, very helpfulA
That's clever, I never thought to do that, but how do stop the pennies from falling out when you expand the spring the last bit to get the hook over, or do you remove the pivot bolts?
Maybe washers instead of pennies and a long bolt or even a nail through the middle of the spring?
And another way I ran into is a variant of RK's, using a ratchet strap. Wrap the strap to the stand and rear tire. Attach springs and pull the stand back. Used this method on My Honda CTX and it was very easy to do. Mike
Big Ups and thanks to everyone who read my post and chipped in. I truly love the Guzzi community.So in the end, I admit I like leverage and making a hard job easy. I visited my local mr tool man and bought a fairly cheap pair of needle nose (ish) vice grip pliers. I put the needle nose up into the spring and clamped them closed and using a big cheater bar against the frame and eased the springs back and rolled them off the posts. Pretty effortless, but I'm not crowing until later in the weekend when I reverse the process successfully ! :-)Fun Times ( even with skinned knuckles)Andy
