the shocks are lovely but what I think you'd really notice more than anything else each and every time you got on the bike is the seating position. The racer has you more tucked in, the Stone/Special etc more upright. That impacts handling but more likely the impact is greater on your back & knees.
Don't discount tires either. I'm much more fond of the MICHELIN Pilot Active that the OEM tires which never felt planted to me.
I run the recommended air pressures in the Dragons (36psi front, 37psi rear). It doesn't get as cold here as it does in New Jersey, but I do take some care to let them warm up a bit before flinging the bike into a corner when I head out for a ride at this time of year. And I agree: the Dragons seem okay, but I've experienced better in the past. I'm eager to try the Continentals ... the real question is whether I want to also switch to a set of wire wheels designed for tubeless tires at the same time. That would be a quantum jump, but a similar quantum suck at the bank account.
We're all assuming the date of manufacture is not an issue? ...
In what context are you saying "date of manufacture"? With respect to tires? bike? What specifically?
I'm assuming he's guessing some less sticky tires might be old.
Ah, okay. I doubt that's much of an issue with 2017 model year bikes, to be honest. I'm sure they didn't manufacture the bikes or tires more than a year before 2017. The Demons (I'm trying to keep the name straight!) work well, they're just not the best tires I've ever owned. Of course, another issue is that I'm not quite the rider I was 16 years ago either... Fifteen years away from the saddle due to health problems and then returning when I was fit again, I feel my skills are coming back quickly but there's a whole long effort of practice and relearning in front of me to go yet. And I haven't gotten any younger in the process.Everything matters. :-)
I'm sure you're right. But if anyone was curious I believe all tires carry a manufacturing date/code in the molding don't they?
Yes they certainly do in order to be DOT compliant. It may only be on one side of the tire though.As far as tire feel, I think the combination of new (barely 100 mi), cold and bias = the hard, skittering feeling of the stock Demons. Could also be the switch from radials and a heavier bike. Hoping some more miles and warmer weather improves my confidence level on these tires.
