I have an opportunity to by a very clean, well equipped 2008 Norge in excellent condition with low kms but it appears from the pictures the fuel tank is swollen on the forward part of the left side. Very visible in the pictures. How much of an issue is this? Bike is very reasonable to the point of being cheap however if the tank needs to be replaced then it may not be such a good deal.Is it a cosmetic issue or is the tank going to rupture over time. I had a Duc that also had this issue but not the the extent that the tank look deformed.TimThanks, Tim
Pull the tank, drain it and put it in your attic in the summer for a month or so with the tank cap open. It will return to its original size. Thereafter use non-ethanol gas.
imperative to keep the tank full when parked
The rest of the bike especially the wonderful engine is worth the trouble to fix your tank woes...trust me on this...
