Sasquatch Jim - I should get the Nitrile... I often clean (the first round anyway) with just pump gas and should probably do more to protect my skin.
Take real care to put as many parts back in as you take out , sounds simple , not always so simple to accomplish Dusty
If you have everything all the way apart find someone who does soda blasting. All the alloy on my T3 came up looking like new and, best of all, you rinse in water.Dave
Progress is being made...1) When assembling joints with paper gaskets, like the oil pipe connections in the lower end etc., do you apply any lubricant to the paper gasket before assembly or put them together dry?2) Any problem with using 18-8 stainless fasteners in AL - life for the front timing cover and sump etc?3) How do you evaluate if the timing chain is OK or needs replaced?
