I'm thinking a warped rotor? While the wheel is turning, the disc is always trying to push the pads open. Tom
The front brake on my rebuilt 79 Convert (still integrated) are pretty weird. I did not rebuild the MC during the build
I should think I would be able to feel pulsation in the lever in that case, right? JD
The blood and guts way to fix it properly is to de lace the wheel and put the hub in a lathe and spin it on it's own axle.A rolling centre in the headstock and a dead centre in the tailstock, will allow you to spin it on it's own races. A lick off the disc mounting faces will have them running perfectly and the discs will give zero pulsation.I had to do it with the Bellagio hub when mounting in the Norge for my wheel conversion.You may not want to be bothered, but if you search "Be your own spokesperson", the process is covered in post #9.
Chuck, I fixed it. I put the dial indicator on the hub without the discs and got a variation of 0.007inches on the hub shoulders (which then of course multiplied at the outer circ. of the disc when I put them on). So I got out a good metal file, and proceeded to bring all hub shoulders into line with the lowest one. After mounts and dismounts of the wheel and checking run out, I got them down to 0.001 on the shoulders, which translated into a 0.003 on the disc at its outer circumference. I took it for a spin and was amazed how such a neanderthal process could result in such a smooth stop and even pull on the lever. John D.
Huzo, perhaps I should have mentioned that this is on a mag wheel and not on a spoked hub. Good advice nonetheless, thanks.JD
