The pressure adjuster is a device which is necessary formaintaining a constant pressure jump on the injectors.The pressure adjuster is a differential type with diaphragm,and is pre-set during assembly at 3 +/- 0.2 bar.Upon exceeding the pre-set pressure, the internal ductopens to allow the excess fuel to flow back into the tank.Note that to keep the pressure jump to the injectorsconstant, the difference between the fuel pressure andthe intake manifold pressure must also be constant.
I assume you mean the fuel pressure regulator (or "pressure adjuster" in the poorly translated OEM manual):40.6 - 46.4 psi (280 - 320 kPa)
On an open loop system like the Jackal that is true. I have an adjustable regulator in the trike. For me the performance advantage is negated by the drop in economy. But you can get to the same place by adjusting the c/o trim. Every increment of adjustment = 1ms of squirt time. It's easier to calculate flow volume using a known rate of flow, while keeping pressure as your constant.
Still wondering how it would run with the regulator connected as in the factory diagram. I'd try it if I had a CO analyzer. Probably get 20 more HP, 11 more miles per gallon and chop 2 seconds off my quarter mile time!
On some vehicles there are alternate injectors available that offer better spry patterns....
