And foot pegs/controls several inches further forward and cruiser wheel/tire sizes.In less than a month, the V7-III will be announced, with the same new cylinder heads, and either 850cc for the Racer replacement, hopefully a Nuevo LeMans, and 750cc for the rest of the V7 lineup, or, hopefully 850cc for the entire lineup for the USA, and the 750cc version for those markets with the 49HP threshold for tiered licensing.
Jas, do you think the V7 III will essentially be a V9? In addition to a different engine than the V7II, didn't MG make some changes to the driveline and final drive of the V9?
But in my defense, I'm big-boned.
Speaking of IBA: I did a lot of long runs with each of my 3 SV650S's, a Guzzi and a few of those Kraut bikes. A favorite mile extender is a collapsible fuel bladder in a tank bag. If the bike is FI find the return line and tap in after the pressure regulator, if so fitted.
Yes, I think it will be mechanically the V9 (including the beefier swing arm & final drive) with the body work, wheel sizes, seat, and foot control positions of the V7II. There may be some evolutionary changes, but, the general theme will be there. The V7 is a great seller for them, they'd be fools to mess with the overall look and feel.
Sure, Cartman!
Hmmmm .... a V9 Roamer with V7 ergos, cosmetics, and large fuel tank sounds like a winner, especially if the V9 suspension is more compliant from the factory than what I've read about V7 suspension. If I weighed 200+ lb, perhaps the stock v7 suspension would be ok. I would like to buy a new bike with really compliant suspension from the get-go, and without having to throw $$ at it.
Bob, I think you're fooling yourself if you think a more base level bike like a V7 or V9 is going to come with decent suspension (the Racer being a possible exception but the extra is in the price).
I don't understand all of the in's and out's that's said here, but it seems like a lot of hand wringing and buggerising around to get get a beaut tourer with acceptable range that's not too massive. Why not go and grab a low mileage Norge and just go, or if that's too big, get an 850 Norge if you can, fill it up and go !!! BTW it doesn't HAVE to have 8 valves... Really. I didn't have to adjust mine @ 80,000 or 100,000. But that's off topic a bit. I haven't done the sums, but the money you'd save would probably pay for an overseas trip of some sort on it. Nordkapp 2017 ???
.... And there's no such thing as an 850 Norge on these shores.
And, the 850 Norge is just as heavy as the 1200.
I figured, like the 850 oil heads, and some of the R65 airheads too right?
Exactly! Well, IIRC, the R65 actually has a slightly lighter, smaller frame, but, I'd have to double check that.
IIRC at one point it did, but not for all of it's production. I believe there were years when it used the same frame.
Relocating the oil cooler on an 1100 Griso is no big deal. The 'Box' it sits in is a big alloy casting. Personally it's asymmetry is one of the things I think makes the Griso outstanding to look at but each to their own. Also with the 1100 and 1200 2VPC models, with the possible exception of the Norge, the oil cooler is pretty much redundant. You could safely delete it entirely in most environments.Pete
as I understand it, the 850 is basically a 1200 engine with smaller bores. The 850 and 1200 probably weigh about the same.
Maybe you could argue that the holes are smaller so therefore it might even be heavier.
Bob, I don't have an answer, but I suspect if it was that simple, they'd do it. I think instead manufacturers do the best they can for the price. And it's a compromise considering the possible sizes of riders.Huzo, I think the problem is the physical size and weight of the Norge or other CARC is an issue The smallblocks are and feel significantly lighter. And there's no such thing as an 850 Norge on these shores.
No. Same bore as the 1100. The 850 has a short stroke. The Bellagio used the same short stroke crank as the 850 but used the 1200 top end to get 940cc.
V9 Racer coming. Should be shown at EICMA in Milan, next Month.Test Mule has been seen sporting Ohlins shocks.
