Wow. I mean, wow. Read what you just typed and think about it. There will be a quiz.
Really, Peter. Think about that. It�s one of the stupidest things I�ve read for a while. You know better than that.
Frgive him Pete, Woolyback maybe ?But what he wants to know is why same faired bike uses more fuel with more modern engine ?Kind of reverse of everyone elseTell him it�s weight, he is light as airOr parasitic losses lose more fuel than cylinder head gains ?
Both our names are Peter.Who's forgiving whom..?
Prob both you �pr for calling you stupidPr-you for wording your question in a way he thought stupidBut, on topic, there was a recent test of all heavy cruisers on mcnews. com.auCali 1400 won the economy part, wasn�t a 2vpc Guzzi in it but all fair comparisons Is relevant in modern world, always was to me, range , even if money irrelevantEfficiency measured in BSFC, simply explained as power obtained for each pint of fuel
See mate, that's where my knowledge base really starts to crumble and I have to improve.Oh and..Pete never said I was stupid, (he knows I'm not)..He said my question was.
Google will get you there quicklyBSFC
I'll only learn enough to get myself into deep water..(too old)And what's BSFC mean ?I can think of a killer acronym, but it doesn't fully apply here.
Because it obeys the laws of thermodynamics. Wow. I mean, wow. Read what you just typed and think about it. There will be a quiz.
Huzo, here is the quiz. 8V Norge & 2V Norge. Same bore & stroke. Same gearbox, same final drive. Each turn of the crank produces the equivalent rotation of the rear wheel. For every power stroke, what is happening in the 8V combustion chamber to produce an energy conversion that is applying more force to the conrod for increased torque?
I suggest Beetle.That in your idealised but realistic scenario, that if both bikes are doing the same work since they are at the same speed and mass, then the 8V crank is experiencing the same thrust from the big ends as the 2V.I would have expected then, that the 8V would have required a lower throttle setting (manifold pressure) since it is reputedly more efficient.This I would have thought, would have translated into less gas gulping.But seemingly not so.
Now to answer your question.During the power stroke, I would have thought that the number of valves meant nothing since they've been closed and the expansion of gas is occurring.If the swirl is better in the 8V, then the better mixing of the fuel/air mixture, should have produced either more thrust for equal mixture mass, or less required mixture mass for equal thrust.Can you forensically pull that reasoning apart and constructively put me on the right track..?
Paul? Have you ever examined the Guzzi 8V top end? If you’re interested drop over some time. I can show you stuff, explain why I think things work like they do, and then you can make your own decisions about how the engine works.Pete
No. A stock 2V never makes more torque than an 8V. The 'consensus' wasn't. You lot can wax lyrical all you want. I don't care whether you prefer a 2V or 8V. I don't care If you quote a world renowned Guzzi gurus. I don't care whether you get 4.5 L/100 or 6.5 L/100. You either accept it or don't. I'm done here. Carry on.
At, say, 150kmh, this arrangement would be reversed with the 4v being more efficient than the 2v.
Yup. And when they 8V it in a few years time? You�ll once again retreat into your superstitious hatred of technological advance. Don�t worry, I get it Martin. You�re just missing out on so much. (I expect a response saying that all the Nuovo hi cams have been a disaster and that the old 2V is superior in every way. Don�t bother. We�ll never agree.)
