In my opinion you won't be able to balance the bike without addition support, the back of the bike will tip down as soon as wheels will leave the ground. I use Big Blue motorcycle lift (http://bigbluemotorcyclelift.com/product/harley-lift-eazyrizer-big-blue/) and in order to lift my Audace I use couple J claps to ensure bike is secure,
Thanks! Any photos of how you secured the front end? We have heard about the machine being rear-heavySent from my iPhone using Tapatalk
I don't think the Cal 1400 are rear-heavy, the way the frame run under the bike leave you with no option but placing the lift arm further to the front (that is if you want to place the bike on the frame pipes) and this will cause the rear of bike to have tendency to drop. I will try to document the procedure tomorrow and will post some pictures.
As the friend in question, I thank you for that detailed description. May need to chop up some tubing and fab up some similar brackets. How beefy are those J-bolts? 3/8"?
