Author Topic: battery type?  (Read 622 times)
Offline Ronkom
    • Virginia Moto Guzzi Owners Club
battery type?
« on: May 20, 2018, 01:11:46 PM »
Hey Guys, I'm bringing an old Guzzi 125 "tuttoterreno" (2 stroke dirt bike) back to life. It calls for a 6v 8ah battery. Any problem w/using a "sealed lead-acid" battery? Or should I stick to the old dry-charged that I'd have to add acid to after I get it? It has a very simple charging system utilizing a "magneto" & a "rectifier" (terms from the wiring diagram).
Thanks,
ronkom
THE MOTRESYKLMAN
Offline Yeahoo Whoyah
Re: battery type?
« Reply #1 on: May 20, 2018, 01:16:14 PM »
Volts is Volts, shouldn't matter.  Size matters, find something that fits into the intended space.
Greg Tillitson
El Dorado Hills Calif.
Offline wrbix
Re: battery type?
« Reply #2 on: May 20, 2018, 01:41:56 PM »
Consider an AGM type battery that gives much more flexibility in mounting position.....tilted, sideways, etc. I’m only presuming they’re available in 6V.
Bill in VA, sometimes FL
"Eschew aphorism"
LeMans IV - "Giulia"
Lario - "Giulietta"
V50III cafe'd - "Leggera"
‘77 Convert - “Sofia”
Classic Mini
‘60 Austin Healey Sprite
Caterham Super Seven Sprint
‘13 Audi TTRS
Grumman AA5B (sold)
Offline Ronkom
Re: battery type?
« Reply #3 on: May 20, 2018, 02:42:56 PM »
Thanks for the replies.
Battery tray & hold down on the bike frame has room for 4.75" wide x 2.25" deep x 4.75" tall.
Battery mart has a "sealed lead-acid" 3.82"wide X 2.21" deep x 4.61" tall. 8.5 AH $13.95....Almost perfect!
R
THE MOTRESYKLMAN
Re: battery type?
Offline JoeKirby
Re: battery type?
« Reply #4 on: May 20, 2018, 08:42:46 PM »
Here is a list of a handful of 6 volt batteries with sizes, may lead you to something.  I had to measure one out for the last battery in I bought for an old Triumph.  Found the measurements here, then cross referenced the YUSA battery with others to find more options.
http://www.yuasabatteries.com/pdfs/Yuasa_Application_Guide_2017.pdf
Never mind, just looked at your measurements, nothing close here.
« Last Edit: May 20, 2018, 08:48:45 PM by JoeKirby »
My favorite rides:
1978 Triumph Bonneville
2005 Triumph Thruxton
2007 Triumph Sprint ST
2010 Moto Guzzi V7
2017 Moto Guzzi V9
Beechcraft BE24R
Online Wayne Orwig
Re: battery type?
« Reply #5 on: May 21, 2018, 09:29:49 AM »
If the system does not have a regulator, I would use a cheap old wet cell, with a vent hose, and keep the water topped off.
An AGM battery has very little water to spare. Normally they recombine the gases back into water. But it you overcharge it much, the safety vents will pop and dry it out really quick.
