If you leave front wheel on, raise rear by putting 2x4 under centerstand. It is enough to wheel out.
If you pull the drive box to lubricate the splines, don't lock it down when you reinstall. Put the axle through first and then lock down the rear drive. If you don't get it 'square' you'll never get the axle back in.Patrick HayesFremont CA
Good advise. I never thought of this. You are referring to taking the gearbox off the swingarm, right. Leaving the 4 acorn nuts loose while installing the axle?
