Oddly enough, a couple of times the starter cranks for a second after I release the start button.
So she's trying to start, so probably not keys or user codes? I was sort of hoping that the secondary set of keys was the culprit (but knew better in my mind).
I'll be taking the tank off for the fuel filter change, but is there any way to tell if the filter has burst on the composit side? (say disruption of fuel in the tank? I forgot how small the fuel filler hole is!) I thought maybe I could see some sort of activity in the tank while trying to crank her over.
Here's the issue. The bike started and ran at the pick up location with his primary set of keys. The PO left a voice-mail that he accidentally forgot to include the primary keys, but there was a second set of (never used) keys in the bag with the manual and extras. I could see some sort of activity in the tank while trying to crank her over.
The "starting" set of keys have been "next day'd" to me. I'm hoping that gets her running. It just seems to be the most simple answer to the puzzle of a bike that started at 1:30pm and then didn't start at 8:00pm. I'll wait for the keys before I start tearing anything else down.Thanks all!
Pete, could the battery be low enough that the computer isn't sending a signal to the coils?John Henry
...This:SEN8I3 / SEN 8I3TDC Crankshaft Position / Crank / RPM / Phase Revolution sensor3-pin connector, with an 90 degree angled head, 30mm long (see photo)For use on Moto Guzzi bikes / GENUINE Magneti Marelli Part Sound correct?Thanks again!richy
I would wire in a 12 V LED or roll your own with a 1K resistor and 10c LED from Radio Shack Red wire - 1K resistor - LED long lead, LED short lead to chassis.
HOLD THE PRESS...RADIO SHACK still exists somewhere???
