Your cat is fried. Good time to go aftermarket on exhaust, perhaps? you can ride it as is, I did it for months waiting for my replacement.The plug caps are almost certainly to blame. Go with XB05F boots/ CPR8EA-9 plugs.
That is good work you have done Timmy.Just to be sure, 0.035" sounds a bit wide historically for a plug gap to me, but could very well be correct.Hope all goes well.Huzo.
You're tempting fate! When they go it it takes only a few minutes for your exhaust to become brown toast.
But they don't just "go" do they?I mean they have to come loose enough to start misfiring, which in and of itself is an indication to pull over and check it out. That doesn't happen without symptoms right?And even then they have to actually come loose and separate to arc or misfire. So there's an element of luck, but also an element of how they've been treated/handled.I'll be sure to schedule it at the next spark plug change/valve clearance check (unless my bike has a different plan).
The browning of pipe does take a few mins to happen but the lost of power was instantly for me.I was lucky as I was just abt to take off from a stop, but it could happen anytime once the connection is lost.The new plug is a lot tighter and doesn’t move as much due to the rubber caps.I mean it’s all up to you...I tempt faith but I lost...
I run a. 026" gap on my '04 Breva according to factory specs. Are the later models that much different?
9 mm ?
