Author Topic: Oil filter wrench size??  (Read 3106 times)
hambonee
« on: September 22, 2011, 11:27:57 AM »
So, my new ..well..new 2007 Norge started leaking quite a bit out of the oil filter. I called Moto International and was pretty much told this was common as heck on new Guzzis as the factory did not always tighten the stock filters enough. Makes sense, easy peasy...
Ok, I was a diesel mechanic for years..I can handle this! The only thing is looks like I will need a cap wrench for the filter to tighten it. Does anyone have any idea what size I should buy? Its smaller than the one I have for my car so I am hoping to be able to buy one from a local shop or autoparts store.
That good 10w60 is expensive stuff to be letting drain out!
Thanks in advance for any help!
  • Guzzi Hero
Re: Oil filter wrench size??
« Reply #1 on: September 22, 2011, 11:37:20 AM »
If it was delivered with the Bosch 3330, any autp parts supplier will have a wrench for it. It'll be black. If it has a UFI, (white) be aware that there are 2 versions, one with 8 flats, another with 12. One wrench definitely doesn't fit all.. ;)
02 Scura RC
87 Lario
82 Monza
Thanks to two wings..
"All a man can ask is to have good friends and to pee with velocity...."
hambonee
« Reply #2 on: September 22, 2011, 12:18:08 PM »
UGH!..mine is white ???
I am pretty surre it has the factory delivered 8 flats. Is this something one can grab easily or am I stuck with riding it to the dealer to get a filter tightened?
Offline blackbuell
  • Guzzi Hero
  • Bikes: 2V Norge, BMW F800GT, YAM RD250
« Reply #3 on: September 22, 2011, 01:02:58 PM »
hambonee,
My '09 Norge oil filter leaked from the start. I did tighten it, but the leak continued until the original filter was replaced by a UFI version by the good folks at Riders Hill during the first service.
Jon
Life is a carnival; two bits a shot.
Offline gsf12man
  • Guzzi Mentor
« Reply #4 on: September 22, 2011, 01:33:17 PM »
This is no help for your UFI filter but if you switch to Bosch 3330 a Hazet 2169 cap wrench from your friendly BMW dealer works perfectly.
Tom K.
MGNOC 21927
Breva V1100
Honda ST1300
hambonee
« Reply #5 on: September 22, 2011, 02:19:50 PM »
Thanks all..may just be easier to swap out the filter myself...
Guess I could try and hold out for another 100 or so miles till the 600 service but hate leaking oil all over the place especially at 10-15 bucks a quart! Cheap bugger here.
THanks for the help all  ;D
Offline kirb
  • Guzzi Hero
« Reply #6 on: September 22, 2011, 02:28:20 PM »
I picked up a couple of filters and a wrench online...the wrench didn't fit the filters they sold me...Grrrr. I had to poke two holes in the old filter to unscrew it with some bent needle nose pliers and tighten the new one by hand.
You will lose some oil in the filter swap, so pick up a liter.
Offline Idontwantapickle
  • Guzzi Hero
  • Just smile and nod......
« Reply #7 on: September 22, 2011, 06:33:30 PM »
Mine leaked too early on. I just parked on the sidestand, cleaned it with some brake-clean and tightened it by hand. Problem solved, in my case anyway.
Hunter
Man, when perfected, is the best of animals, but when separated from law and justice, he is the worst of all.
Aristotle
AMA Charter Life Member
72 Eldo
69 750 American Eagle
2007 Norge rivestimento d'argento
Offline Howard R
  • Guzzi Hero
« Reply #8 on: September 22, 2011, 07:59:28 PM »
This is the one I have.
Picture is a little hard to read, it's an Imperial model IF-768.  Measured with cheap plastic calipers, the INSIDE dimension across the flats is 73 mm.
Howard
Littlestown, PA  USA
1996 Sport 1100
1998 Centauro
MGNOC # L-707
  • Guzzi Hero
« Reply #9 on: September 22, 2011, 08:06:09 PM »
Chuck - these bikes are actually delivered with Bosch 3330 filters from the factory?  Good to know.  I've been running 3300 filters on my 2003 Bonnie for 45000 miles with nary a problem (this is not a filter thread ..... just want to confirm that some MG come from the factory with 3330 filters).
Bob
Main ride:  2008 Guzzi 1200 Sport
Recent addition:  2012 Griso 8v SE (sold Sept '15)
  • Guzzi Hero
« Reply #10 on: September 22, 2011, 08:15:12 PM »
Bob
Seems like I read that at GT a year or two ago.. and mine was delivered with a black filter. I was pissed because my UFI filter wrench didn't fit it. ;D
02 Scura RC
87 Lario
82 Monza
Advertise your products today. All proceeds go back into this website.
Your ad will show up over 10,000 times daily!
