Author Topic: 850T vs T3  (Read 3011 times)
jon
850T vs T3
« on: May 30, 2012, 04:20:18 AM »
Hello.
I am the proud owner of a 1975 850T. Recently, I bought a 1976 850 T3 California with only 36000 km on the clock, this bike looks nice... after setting it up, points, carburetion, synchronization and etc... I feel the T3 is less powerful than the T. Perhaps is the effect of the wind shield... but I would like to hear opinions in this matter.
Regards from the Basque Country
Jon
Offline emac 53
  • Sunday Rider
  • Riding again after 30 years yeeha
Re: 850T vs T3
« Reply #1 on: May 30, 2012, 04:46:45 AM »
What a windscreen !!!!!! Its looks as aero dynamic as brick wall. :o
Offline acogoff
  • Guzzi Hero
Re: 850T vs T3
« Reply #2 on: May 30, 2012, 05:08:11 AM »
Valve Chain Tensioner was an insidious culprit on mine. After the Valtec, power was noticeably improved.
« Last Edit: May 30, 2012, 08:00:56 AM by acogoff »
Marshall County Minnesota USA
Offline SpadapatinaII
  • Guzzi Mentor
Re: 850T vs T3
« Reply #3 on: May 30, 2012, 05:47:36 AM »
Some motors got the mojo.
Offline chuck peterson
  • Guzzi Hero
Re: 850T vs T3
« Reply #4 on: May 30, 2012, 06:50:40 AM »
t3 has two heavier crash bars
heavier saddle
barn door windscreen
floor board set up instead of pegs
rear passenger grab rail
bigger handle bars
all of that little stuff adds up...even at 50 to 75 lbs total it'll make the T feel faster, lighter, nimbler..
  • Guzzi Hero
Re: 850T vs T3
« Reply #5 on: May 30, 2012, 07:00:00 AM »
I always thought T's were a bit better than T-3's, cept for brakes cause of ign timing.
  • Guzzi Hero
Re: 850T vs T3
« Reply #6 on: May 30, 2012, 09:31:05 AM »
Also different jetting on carbs, slightly different final gearing (850-T = 8/35 = 4.375; 850-T3 = 7/33 = 4.714) and different advance curves (springs) and timing.
MGNOC # 8115:
98 Yellow Centauro, 93 SPIII, 1978 LeMans
1977 Convert, 1975 850-T (FOR SALE)
1985 Harley FLTC, 1985 K100RT
2001 Lees-ure Lite Camper
  • Guzzi Hero
  • "Irrelevant" and proud of it!
Re: 850T vs T3
« Reply #7 on: May 30, 2012, 09:37:30 AM »
The 850-T had an 8/37 gearset (4.625) so that's only slightly different than the T3. Ambassadors and the V7 Sport were the only Guzzis that used the 8/35 gearset AFAIK.
http://www.AntietamClassicCycle.com
'69 Ambo
'71 Ambo "Barney"
'72 Ambassador "Special"
'76 Convert
'85 Moto Morini 350 K2
'86 Le Mans 1000
'91 ATK 604
Online Shorty
  • Guzzi Hero
  • Be a simple kind of man.
Re: 850T vs T3
« Reply #8 on: May 30, 2012, 10:08:20 AM »
Don't forget....the Ts were Interceptors, remember?  ;-T
2005 Bonneville/Dnepr Hack
2001 Bonneville
Offline dsrdave
  • Guzzi Hero
Re: 850T vs T3
« Reply #9 on: May 30, 2012, 10:34:53 AM »
I think Chuck is right.  A few pounds here and there along with the barn door windshield would make quite a difference.
2-850T, 2-1000 convert/hacked, V11 sport, V50, centauro, '97 sport 1100, '71 V7 ambo, '76 850 Lemans,CX100,"83 LM III,1000SE, '91 LM V, '07 Griso, '53 super alce,1948 BSA C11
Offline JBU
  • Guzzi Mentor
    • www.joelurruty.com
Re: 850T vs T3
« Reply #10 on: May 30, 2012, 12:35:43 PM »
Agur!  Nola zira?
JBU
Offline mtiberio
  • Guzzi Hero
    • TiberioRacing
Re: 850T vs T3
« Reply #11 on: May 30, 2012, 01:04:52 PM »
A friends 850-T was as fast as my Lemans III. No kidding. Sometimes it has o do with the looseness of the motor...
jon
Re: 850T vs T3
« Reply #12 on: May 31, 2012, 04:42:04 PM »
Agur!  Nola zira?
Oso ondo eta zu?
To explain everybody... the lines JBU wrote are Basque language my mother tongue.
Translating them:
JBU: Hello! How are you?
JON: Fine, and you?
Thank you JBU for noticing where I am from... perhaps you know some Basque people around there...
jon
Re: 850T vs T3
« Reply #13 on: May 31, 2012, 05:00:21 PM »
Thank you all for your answers.
They have helped me to meditate about all  these matters.
About the distribution chain tensioner, recently I have changed the chain and fitted a valtec type tensioner... It is true the engine gains a lot with this simple mod, specially smoothness.
The windscreen is big, I will test the bike without it... is very easy to remove it.
Regarding the weigh I can compare the T with the gas tank full vs the T3 with the gas tank near empty.
The different distributor is another point,  I am tempted to swap distributors between both to see what happens.
About the different jetting, perhaps the reason is related to the unrestricted air admission on the T vs the T3. On the T3 I have the original airbox but recently I have fitted a new K&N filter element inside.
As soon as I can get more conclusions I will post them here.
Offline goog64
  • Guzzi Hero
Re: 850T vs T3
« Reply #14 on: May 31, 2012, 06:36:28 PM »
I'm looking forward to your conclusions.
John F.
Moto Guzzi NeV7C (I finally got the V7C I wanted, in the form of a modified Nevada)
Gone but not forgotten: '07 Nevada, '76-'84-'98 SPEVert, '76 850 T3, '84 V65, '01 Stone Metal, '05 Nevada
Offline Denis
  • Guzzi Mentor
Re: 850T vs T3
« Reply #15 on: May 31, 2012, 06:43:27 PM »
My 850-T was crazy fast and a blast to ride. I think they are better looking than T-3s as well, despite the better brakes on the latter.
  • Guzzi Hero
Re: 850T vs T3
« Reply #16 on: May 31, 2012, 10:01:43 PM »
ah, one more, T's have one front rotor, T3's have 2 front rotors, double the weight on the springs..
Offline Matt
  • Guzzi Hero
Re: 850T vs T3
« Reply #17 on: June 01, 2012, 07:59:35 AM »
Years ago the local Guzzi gurus dissected a T and T-3 distributor to see the differences, they're identical except for lighter advance springs on the T bringing it to full advance faster. The T-3 didn't get to full advance until well past working RPM while the T was there when it needed to be.
Matt
Everett, WA
Guzzi bit
1250 Bandit
SV650
Offline JBU
  • Guzzi Mentor
Re: 850T vs T3
« Reply #18 on: June 01, 2012, 08:58:31 AM »
Jon,
Yes I know quite a few Basque people.  My parents are both from there.  Mother  (Sorhapurru) near St Palais, father Armendaritz.  I have plenty of Aunts, Uncles and cousins living all over the basque country.
JBU= Jol Bertrand Urruty
JBU
Harper's Moto Guzzi
Harper’s Moto Guzzi does all types of repairs on your Moto Guzzi. Don’t wait till spring to fix those annoying little problems. We also do component work, meaning you can send us your engine, transmission, rear drive, starter, carburetors or brake parts and we can get them serviced and ready for your 2017 riding season now. You can call us at 816.697.3411 and discuss your issues and get your problems resolved.
http://www.harpermoto.com
Take a gander around New Zealand on a Moto Guzzi from Guzzi Gander Ltd rentals.
Check the website’s Gallery page for images of great New Zealand scenery
http://www.guzzigander.com
