Author Topic: V7 Stone dressed with Breva 750 panniers  (Read 34930 times)
Offline Mike744
« on: October 02, 2012, 06:44:21 AM »
Today I mounted a set of Breva 750 panniers with a Hepco & Becker frame on my V7 Stone. It all went together in 15 minutes or so. Wonderful quality gear. The only down side is that the grab rails have to be left off.
Re: V7 Stone dressed with Breva 750 panniers
« Reply #1 on: October 02, 2012, 07:15:31 AM »
Were the HB racks themselves specifically for the Breva 750 and not the V7?
Offline Mike744
« Reply #2 on: October 02, 2012, 07:23:45 AM »
This H&B frame was listed as correct for V7 Classic however it mounts on the Stone perfectly. The Breva frame would not fit the Stone.
« Reply #3 on: October 02, 2012, 07:55:29 AM »
I didn't think it would, but I never noticed the rear crossbar sitting so high before so I wondered.
« Reply #4 on: October 02, 2012, 03:50:18 PM »
The bar can be force-fitted low.  That's the way mine came.  I saw it looked wonky and just flipped the bracket when I installed the H+B lock plates that didn't come with the bike.
« Reply #5 on: October 02, 2012, 04:11:29 PM »
That looks fine Rocker.
Offline Mgv7rider
« Reply #6 on: December 16, 2012, 12:33:57 PM »
Your V7 Stone looks really amazing with the panniers on! I am so close to buying a v7 stone at this coming motorcycle show in Toronto Canada! If you get a chance, could you post a pic without the panniers...I would like to see what it looks like with the HB Frame. So rush and thanks in advance...happy riding (that is if you are in a climate to ride at this time of the year...I am all packed away for the season! :(
Current rides:
2013 Moto Guzzi V7 Stone (matte black)
1980 Vespa P200e
Past rides:
2004 Yamaha YZF 600R (sold)
1996 Yamaha vStar 650 (sold)
ronatd
« Reply #7 on: December 16, 2012, 08:36:19 PM »
Is that the new "Touring" windscreen from Guzzi for the V7 line?
Online Air-Cooled
« Reply #8 on: December 16, 2012, 08:40:59 PM »
You did a nice job of mounting and they look functional, but I can't help but thinking that the Stone is a simple free machine that should look unfettered with bags.
1973 Moto Guzzi V7 Sport, 2016 Moto Guzzi Stornello, 2023 Vespa Primavera
« Reply #9 on: December 16, 2012, 09:08:40 PM »
That looks like the OEM shield, but for the record the OEM shield is not a new item.
Offline Mike744
« Reply #10 on: December 18, 2012, 04:49:47 AM »
Before I mounted the panniers I was concerned about how the bike would look with the frame and no bags. However, since installing the panniers I have found them so useful and so unobtrusive that I have never ridden the bike without them.
The windscreen is the same Guzzi item that has been available for the Breva and Classic for years.
« Reply #11 on: December 18, 2012, 06:40:23 AM »
I'm going to powdercoat the racks black for mine. It helps with durability (as the cheap finish on the chrome HB's is known to pit/corrode), but it also helps downplay them visually. Betcha that would really work well on a black Stone.
oceanluvr
« Reply #12 on: December 18, 2012, 08:03:19 AM »
Kevin I owned a large powder coating facility for years in S. Florida and even though powder coating is a great system with lots of applications, there are some caveats.  When you speak of PC chrome the best bet is to completely strip the chrome.  Let me quote from one of my colleagues: "Chroming; like powder-coating, is adding material to a substrate (the aluminum, steel, etc underneath). If the chrome is chipped then chances are that the initial preparation of the steel and/or aluminum was not prepared properly to begin with and anything you put over the chrome will come off in time, but not as quickly as the chrome itself.
Adding a powder coat (or paint) over chrome will only slow the rate of loss since the powder is bonded to the chrome (more on that later). If the chrome comes loose, anything bonded to the top of it will fall off by default (excepting tension bonding on the edges of the chrome "flake").
So, there we go. In short, if the chrome is flaking off then adding a powder coat or paint will simply slow down the process if you do not remove the loose chrome"
« Reply #13 on: December 18, 2012, 08:27:59 AM »
I appreciate the info and guess I should explain further.
I did this already, with the HB racks from my Jackal and the results were SPECTACULAR.
Lasted perfectly for many years.
With the new Stone racks I plan on having this powdercoating done right away over top of the pristine/unblemished finishes that are there now.
The HB chrome racks (at least those for the V7) may have a tendency to corrode over time (I think mostly at the weld spots), but I don't think they come that way.
If they are anything like the HB racks for the Jackal I THINK (tell me if I'm wrong) sealing the chrome while still pristine should work fine.
oceanluvr
« Reply #14 on: December 18, 2012, 08:31:55 AM »
K- yes you are correct in that if the chrome is in good shape you should be fine with top coating with a PC.  Any coating, whether paint or powder coat is only as good as the substrate to which it is applied.
« Reply #15 on: December 18, 2012, 08:41:04 AM »
Excellent - glad to hear.
And thanks for the lesson/experience. I bet more people here will benefit from the advice!
RIDE SAFE!
Kev
Chicago Mark
« Reply #16 on: December 18, 2012, 10:01:03 AM »
Anytime I ever had an item powder coated (aluminum, steel, chrome) the powder coat shop always sand blasted the item. The results were always excellent and always better than I expected. They always used a high temp tape to protect any part of the piece that shouldn't get coated to.This was many years ago and the shop was in Santa Ana, CA. Would it be better to strip the original and suspect chrome in this case? Even though the part is new.
Thank You,
Mark
« Reply #17 on: December 18, 2012, 10:16:15 AM »
I suspect my shop sand blasts too, but I haven't verified.
oceanluvr
« Reply #18 on: December 18, 2012, 11:00:30 AM »
Thank You,
Mark
Mark, we did a lot of OEM work and some of that required re-do of defective parts.  Our specs from the auto manufacturer required us to always strip the part down to the bare substrate.  However if you are confident the chrome is in good shape you may opt to skip that step but if there is any degradation in the finish, such as peeling, bubbling etc, by all means strip it down.   Additionally if you want to insure a superior finish, after stripping it by either sand blasting or chemical stripping we always then applied what is called a conversion coating to the bare metal, which increased the corrosion protection and also increased the surface hardness, but that is not necessary unless the part is really subjected to extreme conditions.
Offline mojohand
« Reply #19 on: December 18, 2012, 05:35:29 PM »
Moving back to the bike...I love it! Looks great...close enough to my '04 Breva 750 that I'd be tempted again ;)
« Last Edit: December 18, 2012, 05:37:00 PM by mojohand »
Richmond, VA, USA
2020 BMW R1250RS
Previous: 2000 Jackal, 04 Breva 750, 06 Breva 1100, 07 Norge, 09 Griso, 12 Norge, 14 FJR, 14 Striple, 16 SpeedTriple, 18 KTM Super Adventure S
ronatd
« Reply #20 on: December 18, 2012, 05:56:54 PM »
How sure of that are we? In all the pictures I've seen it appears a bit taller, and it has a different part number than the screen in a Breva 750 accessory catalog.
« Reply #21 on: December 18, 2012, 06:16:31 PM »
I suspect it's the same as the earlier V7 shield, but wouldn't be surprised is it was different from the B7 shield.
Offline Mgv7rider
« Reply #22 on: December 20, 2012, 09:49:16 PM »
Thanks for the pics without the panniers...bike looks amazing with or without! I am glad to hear that the really do not get in the way of your day to day riding! Happy riding and have a great holiday! I will post some pics of my bike this spring...v7 stone here I come!
Current rides:
1980 Vespa P200e
Past rides:
« Reply #23 on: December 20, 2012, 10:12:27 PM »
So I noticed today while ordering the HB racks that the photo shown on the HB website has the rear crossbar mounted in the lower position.
Does this only work on EU license plate setups?
Offline Mike744
« Reply #24 on: December 21, 2012, 05:52:18 PM »
We are very sure. Part 887772 for each.
http://www.motoguzzi.com.au/acc_887772breva.html
http://www.motoguzzi.com.au/acc_887772v7cafe.html
http://www.motoguzzi-us.com/motorcycles/v7-stone/accessories.html
I look forward to the photos. Enjoy the anticipation.
The rear crossbar can be assembled high or low to suit your needs
ronatd
« Reply #25 on: December 22, 2012, 01:48:01 PM »
http://www.motoguzzi-us.com/motorcycles/v7-stone/accessories.htmlI look forward to the photos. Enjoy the anticipation.The rear crossbar can be assembled high or low to suit your needs
I have a Breva 750 accessory catalog that gives the part number as MG977431, but the description is the same ("New Windshield") and the picture looks similar.
guzzipete
« Reply #26 on: December 22, 2012, 02:00:38 PM »
I think that this is the windscreen you are thinking of. I have it installed on my V7C. Part number is
GU973217200002.
http://fastrixx.com/shop/index.php?l=product_detail&p=71529
« Reply #27 on: December 22, 2012, 08:43:32 PM »
I have a `04 750 Breva and it's Hepco-Becker bag mounts are not chrome.  ???  Maybe you got Nevada mounts.  ;)  I didn't have to take my passenger grab handles off, but with the bags on you use the bag handles instead for things like putting it on the centerstand.   :)
« Last Edit: December 22, 2012, 08:51:18 PM by Arizona Wayne »
trix400
« Reply #28 on: April 04, 2015, 08:18:26 AM »
I just got the same windshield for my V7 Special. I'm having a little problem removing the bolts under the speedo/tach housing. Any advice on getting those out?
trix400
« Reply #29 on: April 04, 2015, 09:12:18 AM »
