Author Topic: Inside Diameter of CalVin Bars?  (Read 842 times)
Offline keithl
  • Weekend Warrior
« on: April 11, 2013, 11:50:16 AM »
Does anyone know off-hand the inside diameter (in mm's) of CalVin Handlebars?   I'm looking to buy a
throttlemeister and don't have the bike with me to measure myself.  Thanks.
« Last Edit: April 11, 2013, 01:24:56 PM by keithl »
Online Kiwi Dave
  • Guzzi Hero
    • Guzzi Gander Ltd
Re: Inside Diameter of CalVin Bars?
« Reply #1 on: April 11, 2013, 02:39:37 PM »
The CalVin has bar end weights installed, with a crude bolt and nut expanding a bit of rubber to hold them in.  Won't these interfere with the Throttlemeister?
  • Guzzi Hero
« Reply #2 on: April 11, 2013, 04:21:52 PM »
Throttle Meister replaces the factory bar ends.
Aux Arcs
1996 Moto Guzzi Sport 1100
  • Guzzi Hero
« Reply #3 on: April 11, 2013, 04:29:30 PM »
http://throttlemeister.com/app/inventoryapp/moto_guzzi/inventory_list/83-0.html
The control ends of the bars are normal 7/8" OD.  I'm sure a quick message to the company will get the answer on which you should use.  Just make sure whether, or not, your bike has plugs in the bars.  That will make a difference on the hardware.
Aux Arcs
Offline keithl
  • Weekend Warrior
« Reply #4 on: April 11, 2013, 05:11:07 PM »
Actually, they are the ones who asked the question.  They told me they need to know the inside diameter of bars before they can tell me which one will fit.
  • Guzzi Hero
« Reply #5 on: April 11, 2013, 06:39:58 PM »
Hmmm...  You'd think they...  Oh, never mind...
Well, If no one provides you with an answer tonight, I'll measure the California EV bars I have on the shelf in the garage, when I get home from work.
Aux Arcs
Offline keithl
  • Weekend Warrior
« Reply #6 on: April 11, 2013, 06:49:38 PM »
Yeah I know.  I can only think nobody has bought one for a CalVin yet and they never looked into it.
Online rodekyll
  • Guzzi Hero
« Reply #7 on: April 11, 2013, 07:48:24 PM »
There ought to be only two sizes on that bar end -- Harley and everyone else.  How many sizes does throttlemeister offer?
Online Sheepdog
  • Guzzi Hero
« Reply #8 on: April 11, 2013, 08:35:29 PM »
It should be about 3/4" (assuming the wall thickness is about 1/16").
"If everyone is thinking alike, then somebody isn't thinking." George S. Patton
  • Guzzi Hero
« Reply #9 on: April 11, 2013, 08:49:51 PM »
I do know the OD is 30mm.
Cam
Cam - NJ Rep MGNOC
'14 V7 Special
http://mgnocnj.forumcircle.com/index.php
  • Guzzi Hero
« Reply #10 on: April 11, 2013, 08:56:10 PM »
Cam
That's the part you see.  They are stepped down to standard 7/8" OD under the switches and grips.
Aux Arcs
Offline keithl
  • Weekend Warrior
« Reply #11 on: April 12, 2013, 07:54:00 AM »
Yep.  I believe the outside diameter is 22mm, so I would guess the inside would be about 20mm.
  • Guzzi Hero
« Reply #12 on: April 12, 2013, 08:45:30 AM »
The EV Touring bars I have are 18mm ID.
Aux Arcs
Offline keithl
  • Weekend Warrior
« Reply #13 on: April 12, 2013, 08:52:47 AM »
Thanks a bunch! I appreciate it.
Online rodekyll
  • Guzzi Hero
« Reply #14 on: April 12, 2013, 03:18:04 PM »
I dug a tote out of the snow and pulled three different EV handlebars.  All measure 18mm ID.  DOn't know if the Vintage is different, but I suspect not.
Offline keithl
  • Weekend Warrior
« Reply #15 on: April 12, 2013, 06:51:17 PM »
Thanks, i called today and ordered one.  They said they have never sold one for a CalVin.
Offline spridget
  • Guzzi Hero
  • 2007 California Vintage 1962TR4 1967TR4A 1976TR6
« Reply #16 on: April 12, 2013, 11:09:36 PM »
I went thru the same thing when I wanted to order a set for my Calvin, what size bars, etc. Got side tracked with another project and never followed thru. Would be curious and thankful if you could post the part #'s you receive and if they fit / work properly. Thanks
Plum Boro / Pittsburgh Pa. A few miles from the PA Pike, Monroeville exit.
Offline keithl
  • Weekend Warrior
« Reply #17 on: April 13, 2013, 10:12:15 PM »
Sure. I'll report back when I get it installed.
Offline spridget
  • Guzzi Hero
« Reply #18 on: April 17, 2013, 12:05:52 AM »
Thanks keithl............. ....
Offline keithl
  • Weekend Warrior
« Reply #19 on: July 02, 2013, 01:47:53 PM »
Sorry it took so long.  Here is the info on my Throttlemiester receipt:
Moto Guzzi - others with 18mm-I.D. Bars  Standard:    FT & AL
It seems to work well enough so far.
Offline spridget
  • Guzzi Hero
« Reply #20 on: July 02, 2013, 10:59:53 PM »
THANK YOU !!!!
Advertise your products today. All proceeds go back into this website.
Your ad will show up over 10,000 times daily!
