Author Topic: Guzzidiag questions?  (Read 1196 times)
Offline Waltr
  • Guzzi Hero
    • Europa Macchina
« on: January 08, 2014, 05:21:43 PM »
I downloaded Guzzidiag and stored on desktop for quick access.   I plugged in the cables I bought.  Walked out to garage with my laptop and connected the  cable to the laptop.  I clicked on Guzzidiag and indicated english and selected Norge 1200 GTL for my 2012 Norge.  When prompt said Ignition on I turned on the key and waited a few seconds and then a prompt said ignition off and I turned off the key.
  If I hit connect again it goes through the same sequence.    WHAT am I doing wrong?  When it says ignition on do I need to start the bike and not just turn on the switch?  I have not started bike because I hate to run a bike without riding it, just trying to determine if I have what I need.
Walt
www.motoguzzipa.com
2012 Norge
Online Unkept
  • Guzzi Hero
Re: Guzzidiag questions?
« Reply #1 on: January 08, 2014, 05:24:06 PM »
Walt
Is your kill switch on? It needs to be in "ready to start" push the starter button and GO mode.
Otherwise, check your COM port, change that to see if it helps.
-Joe
Unkept Uncaged- Youtube Channel
http://tinyurl.com/lh5zbus
Unkept's V11 LeMans Restoration Thread
http://tinyurl.com/md7tmdo
Offline pauldaytona
  • Guzzi Hero
    • Paul's fast Guzzi Page
« Reply #2 on: January 08, 2014, 06:14:43 PM »
well you did not tell if you have the driver for the cable loaded.
This one:
http://www.ftdichip.com/Drivers/CDM/CDM20814_WHQL_Certified.zip
Windows version?
Paul
Daytona 1225, Stelvio 1151
Offline Waltr
  • Guzzi Hero
    • Europa Macchina
« Reply #3 on: January 08, 2014, 06:23:48 PM »
Ignition switch is on, the only port that shows up in preferences is com port 4.  I am connected to the connector that is near the fuse box that has two wires going to it.  The red LED illuminates when the ignition is turned on.  The cables are 16 pin if that means anything.  I ordered off the same Amazon ad the someone else used and said they worked for him.
www.motoguzzipa.com
2012 Norge
Offline Waltr
  • Guzzi Hero
    • Europa Macchina
« Reply #4 on: January 08, 2014, 06:54:45 PM »
When I hooked up the cable it went through the install driver sequence.  I was not able to download the zip file instead went on the website and downloaded the 32 and 64 bit drivers for windows 7.  I guess I could take the cable apart to find out what chip is in there.   I am way above my element with this stuff but I read everything I can.
www.motoguzzipa.com
2012 Norge
  • Guzzi Hero
« Reply #5 on: January 08, 2014, 07:19:16 PM »
Red LED? Inside the OBDII cable?
It should light when you connect the cable to the battery. All of the ones I have seen were blue, not that it matters.
Two wire connector. Can that be the ABS connector?
Scientist have discovered that people will believe anything, if you first say "Scientist have discovered...."
Offline Waltr
  • Guzzi Hero
    • Europa Macchina
« Reply #6 on: January 08, 2014, 07:29:43 PM »
There is a white connector with three wires but no way are the connectors compatible. How many connectors under the hood?
www.motoguzzipa.com
2012 Norge
Offline Waltr
  • Guzzi Hero
    • Europa Macchina
« Reply #7 on: January 08, 2014, 10:12:54 PM »
even though the connector read KKL VAG-COM for 409.1 it does not have the correct chip. The chip inside says CH340T.  I did a search on a Diagnosis Kit on this site and found another link for what seems to be the correct cable with the needed chip for sale on EBAY.  Ordering that one. Will have to wait for it to arrive from China.
www.motoguzzipa.com
2012 Norge
Online JayDee24ca
  • Weekend Warrior
« Reply #8 on: January 08, 2014, 11:02:08 PM »
Same routine I went through two months ago with the cables I bought. I feel your pain.  :(
JD
'74 Eldorado
'79 Convert
'87 SPII
'00 Quota
Offline leafman60
  • Guzzi Hero
« Reply #9 on: January 09, 2014, 06:32:33 AM »
I wish someone could get this sorted-out.  I'd like to go to Guzzidiag but there seems to be great problems obtaining the correct cables that function properly.
Offline kirb
  • Guzzi Hero
« Reply #10 on: January 09, 2014, 08:34:47 AM »
I would love to pre-package working cables that are ready to go, but now you have a middle man. I have already been on the wrong end of 'how dare you cover your expenses and waste a bunch of your time' when it came to sending NTX fuse holders to Germany because they could do it themselves for $5 cheaper.
Confirms the rule of never turning a hobby into a job. Once sorted, the software is awesome. It's worth a little effort to get there.
Offline Waltr
  • Guzzi Hero
    • Europa Macchina
« Reply #11 on: January 09, 2014, 08:43:57 AM »
This is the cable I have on order          http://www.ebay.ca/itm/200872645185?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Hope this works and will fit the 16 pin cable I have to mate with it already.
www.motoguzzipa.com
2012 Norge
  • Twitter: @Mayor_of_BBQ
  • Guzzi Hero
    • Dumb Tweets
« Reply #12 on: January 09, 2014, 09:16:39 AM »
Do you also need a driver for the cable for the Mac OS? Or only on windows?
www.SweetenCreekBrewing.com
~Asheville NC Craft Brewery~
~Arrive via Guzzi I'll Buy You a Pint~
1971 Ambo *barn fresh*
1976 Robin *beer runner*
1984 V65 *the astronaut*
2007 Breva 1100 *the prospector*
Offline pauldaytona
  • Guzzi Hero
« Reply #13 on: January 09, 2014, 09:22:10 AM »
 well there is a ftdi driver for mac too. If you don't see a com port, you have no working driver:
http://www.ftdichip.com/Drivers/VCP.htm
Paul
Harper's Moto Guzzi
Harper’s Moto Guzzi does all types of repairs on your Moto Guzzi. Don’t wait till spring to fix those annoying little problems. We also do component work, meaning you can send us your engine, transmission, rear drive, starter, carburetors or brake parts and we can get them serviced and ready for your 2017 riding season now. You can call us at 816.697.3411 and discuss your issues and get your problems resolved.
http://www.harpermoto.com
Take a gander around New Zealand on a Moto Guzzi from Guzzi Gander Ltd rentals.
Check the website’s Gallery page for images of great New Zealand scenery
http://www.guzzigander.com
