Along with the kneeling pad, Sears has a decent and inexpensive shop stool. 30 bucks gets you a stool with wheels that lets you work low and still be able to sit, and roll around.Boy, once you get things back together, you're not going to know how to act. ;DJohn Henry
Just unscrew, cut off 1/4inch with your dykes, and screw on your new cap.
Great work...it's coming along nicely. Here is the knee pads I use. Very good quality pad./snip
I fin fit really satisfying to see a kid knuckling down and working it through. I have customers who cry like babies if their bike blows an indicator globe.While the bevelbox is off I'd suggest pulling the pinion carrier and crownwheel plate. The pinion nose bearing is a bit weedy on V11's. Look at the CW&P at the same time. I have a second hand set I'll donate as an 'Encouragement Award' if you need a set. Chuck can learn ya how to set 'em up. ;DPete
:+1IMHO a kneeling pad is a much idea than knee pads which can actually damage your knees by not centering your weight on the patellas, when in a kneeling position.How do I know this, building work.Unkept it must be great to get all those bits replaced you've been needing to for ages. :bowRob
Joe, I upgraded to a Matco stool a couple of years ago. You can have my ancient Sears stool.Good find!/snip FIFY ;D
Rare in the USA as hen's teeth Champion spark plug caps. The stock caps on a V11 Sport. I only needed one, but the shipping was the main cost so I bought three. ;D These are only available from England it seems.
Also of note, by sanding down those pins on the plastic controls, the kill switch and the turn signal switchgear are a tiny bit loose and could shift. This is because the plastic versions don't create the torque on the bars that the metal pieces do... and on that Chrome it's slippery. I could deal with it but I like safety, so I have a plan to use some of that cloth for grip and wrapping a layer under those control pieces. Stay tuned.
Good pics Joe ;-T
Hi Joe,What a thread! You are getting close now :popWith the Hot Hands, if you haven't already, use a relay for the power source, it'll save you some heart ache one day and it is easier when you are disassembled to this level ;-TClutch bleeding, let gravity do the work for you. If you can get the slave cylinder higher than the handle bars or lay the master on the ground so you are pumping air upwards and percuss the hose with a spanner to keep the bubbles on the move and let it set overnight to repeat the bleed the next day.Regarding the headers, if they are stainless steel, I use hydrochloric acid and paint it on and rinse after 5-10 seconds and it acts very fast then polish with chrome polish or you can leave as is if you prefer the matte finish. Do a test in a non visible area first.Regards,Adam
Where from in the UK did you get them please? I got some replacements ages ago for my Cali and never fitted the cos I hadn't realised they wern't red untill they arrived ::)
Keep it up! One step forward, two steps back is *not* unusual. ;D You can make stainless steel shine like a pewter dollar if you want to put in the labor. You start with coarse enough wet or dry paper to get a smooth surface, (400 grit, if you're lucky) then sand with progressively finer grades up to 600 grit. From there, you can buff it out on a buffing wheel with rouge. Keep your oily fingers off before getting it hot the first time, and it will turn a beautiful golden color.Reminds me of work, though.. ;D
Glad you spotted the noisy wheel bearing before it ... ;-TRob
"Maybe" another glitch waiting in the wings.. have you made sure that your new bars will actually clear the fairing? ;D :BEER:
Rather than cloth, you might try cutting a small strip out of an old bicycle tube to install under the switch assembly. It won't hold any moisture and should prevent movement better than cloth.
"Wow, that's a good idea. Too bad I don't have bicycles/old tubes. Huh Maybe I'll think along the lines and see what I can find... something else rubbery, thin, and grippy?"humm - thinking with my other head.....Mark
;DI actually used what you are thinking of on this bike already... to cap off the frame ventilation downtube when flushing out the rusty oil. To fix a Guzzi, you only need a rubber, a hoseclamp, and a copper hammer. :BEER:-Joe
Hmmm, now WG is getting ads for erectile dysfunction specialists.. ;D :BEER:
Good work Joe. ;-T If you don't want the Valtek tensioner I'll buy it off of you.
Awesome job!Where did you get those bars? Do you need to lengthen cables and hoses to use them? Sorry if you explained already!Thanks
Loctite is starting to run low... ;D Noticed how I've already scratched my newly repainted subframe? Don't wanna talk about it! :DGot to loctite the monster bolts which hold the damn thing on!The "short" bolts for the subframe go up top, the fatter longer bolts connect the lower half to the timing cover. Coming together now...Wooooo
Looking good!Looks like you will have it ready for the national, at which I hope to see it/ meet the owner!
He did. I forget what page of the thread.. :D
Joe....you should have it up and running for the National next month. Wish I could be there Elkader is a fun rally. ;-T
There's no danger of them there bolts coming out and I can see why you're running short of Loctite ;DJoking aside - you're doing a grand job ;-T
You are wasting thread locker, Grasshopper.. (Guzzi content) The amount on the end of the lowest bolt in your picture is about right. That stuff's expensive. ;)On the clutch bleed.. you may have better luck with a re-purposed turkey baster and pressure bleed it.
Since you won't be working on your bike at the National. You can do some of the fun stuff. Parade, visit the Field of Dreams, National Motorcycle Museum, Gunder burger, St. Olaf pork tenderloin sandwich. etc. ;-T
