Author Topic: Freshly serviced breva dies on side of the road.. Your guess?  (Read 42438 times)
Just had my breva at riders hill for spring service
It was running ok, just a tune up
It had
New plugs outter & inner
Canisterectomy
New fuel filter
Valve adjustments
Brake job
Gps pigtail wired to battery
Tb cleaned/ balanced
Correct updated map for stain tune exhaust
I put a new air filter in about 200miles ago
I got the bike home, took it off the truck and ran it to the corner store and back >4mi
It ran perfect
Parked it two days
Went to ride today, started and purred on first flick
As I pulled out of my driveway onto the street it just cut out when I pulled in clutch & stopped at sign
I live at the top of a hill so I just rolled on and tryed to start it.. No dice
I try to bump start it down the hill.. No go
I pull off at a flat place, try to start it, now the starter keeps turning even when I take thumb off the button, have to hit kill switch to stop it
Key off, key on
Big red SERVICE light is on
Key off key on
No service light, normal needle sweep, but hit start button clunk then nothing
Key off count to ten key on
Normal sweep, starter turns, keeps turning when I release button
Till kill switch
Key off on clunk
Etc
Etc
Etc
Little less than 1/4 tank of gas (opened and looked can't see it but it's sloshing)
Checked main 30a fuses both good
Battery connects tight
HIT ME WITH A GUESS... I'm a mile from my house DOWN. BY. THE. RIVER.
Andrew Thomas Evans
Re: Freshly serviced breva dies on side of the road.. Your guess?
« Reply #1 on: March 11, 2014, 03:57:24 PM »
Sounds like a switch is preventing it from getting going.
Just IMO and I'm about a ready to leave from work.
Offline MotoGuzzi
« Reply #2 on: March 11, 2014, 04:04:52 PM »
Bad connection, This >"Gps pigtail wired to battery"
« Last Edit: March 11, 2014, 04:08:49 PM by MotoGuzzi »
« Reply #3 on: March 11, 2014, 04:05:42 PM »
When you hit the starter button the motor should turn for four seconds, if it doesn't fire in that time the starter should stop spinning. If its longer than four seconds and its still spinning there has to be some form of direct feed event happening to the starter or the ECU is continuing to send a start command to the starter relay.
Obvious places to look are the sidestand switch and clutch switch but these should not allow the starter to spin.
Offline kckershovel
« Reply #4 on: March 11, 2014, 04:23:00 PM »
(Points, Carburetors) ummm all kidding aside I'm guessing it has something to do with the GPS pigtail. That sounds like the only electrical work done. That or a pinched shorted wire that happened during the work. My normal diagnostics would say to pull the plugs and check for spark and to listen for fuel pump priming sound. Other than that I don't know enough about the newer bikes to be of any help.
« Reply #5 on: March 11, 2014, 04:39:45 PM »
My first call would be to Riders Hill .
Sent from a submarine in Oklahoma .
« Reply #6 on: March 11, 2014, 05:23:42 PM »
That's what any good submarine captian would do, yellow or otherwise ::) ::) ::)
« Reply #7 on: March 11, 2014, 05:41:44 PM »
The pigtail is wired direct to battery and fused
Tried to call riders hill couldn't get them around 4:30 today
Side stand switch seems to be working-- at least the idiot light on dash indicates the correct position
« Reply #8 on: March 11, 2014, 05:42:22 PM »
As for clutch switch, I tried starting it in neutral with clutch out and in
Offline kckershovel
« Reply #9 on: March 11, 2014, 06:00:22 PM »
Can you hear Fuel pump? Did you pull spark plug and check for spark?
I will assume the Air-filter is not clogged shut so first we need to know what of the other 2 things needed to run the bike is not getting. fuel or spark. Now I go about things differently than others. If it were me I would check spark first. If spark is present I would spray a little starting fluid into the throttle body to see if it tries to start or runs momentarily. If so you would then only need to figure out why the bike is not getting fuel.  If there is no spark well then you just need to figure out why?
« Reply #10 on: March 11, 2014, 06:24:38 PM »
Likely, some mystery connector/connection got loosened when they added that GPS wire.
Investigate the areas it is in closely.
« Reply #11 on: March 11, 2014, 06:38:52 PM »
Possible that one of the electrical connectors serviced was not seated 100% and backed out enough to disconnect. Try unpluging and repluging anything you can get to. Good Luck!  ;-T
Online Guzzidad
« Reply #12 on: March 11, 2014, 07:11:24 PM »
Probably a weak battery. The voltage is there but it has lost it's punch. My Triumph Tiger has done the same thing to me a couple of times at the end of its battery life. Time spent in the shop is often with the key in the on position for extended periods of time. That can finish off a battery that otherwise seemed ok. You can't bring it back, it has lost it's will to live.
« Reply #13 on: March 11, 2014, 07:16:42 PM »
 :BEER: :pop Ian should be around in the AM tomarrow.
Offline EvanM
« Reply #14 on: March 11, 2014, 09:27:12 PM »
Fuel filter installed in the wrong direction?
2007 Breva 1100
biking sailor
« Reply #15 on: March 12, 2014, 07:06:41 AM »
Easy thing to do is pull an outer plug after cranking to see if it is wet with fuel.  When my Breva lost it's fuel filter, the plugs were very dry.  I would rule out fuel issue by doing that.  Could be simply a fuel line came off from when the filter was changed (or filter wrong direction as mentioned before).  Then on to electrical.
Offline Scott of the Sahara
« Reply #16 on: March 12, 2014, 07:55:00 AM »
I did that to my own filter. The hose clamp fell off after 4 miles. I was home when it failed, but the 4 miles was to the gas station to fill up. So then I had to remove a full tank and remove the fuel pump again. this time I used better hose clamps.
« Reply #17 on: March 12, 2014, 08:53:17 PM »
Thanks for all the suggestions guys.
I got the tech who worked on it on the phone. His only suggestion was check the tubing to the throttle bodies and make sure they are connected? Lol
I reinstalled the charged battery which of course didn't help shit.
At this point I was going to load it up in the back of the truck. But I've never pushed it up the ramps solo without driving it up under throttle.
I found a likely spot further down the hill where I can back the truck and roll it in without the ramps being too steep.
Of course my straps aren't in the truck, they are in my storage unit wrapped around this damn oven I just bought and unloaded solo...
So a trip to Great Northern for furniture dollies to put the range on.. Take the straps off. Back to the bike.
Only now the temp has dropped 20degrees and the wind is howling.. And what's that? Sleet?!? Awesome.
I'm not dumb enough to try and load it solo in the wet so..
My bike is still sitting at the bottom of my street
Offline Markcarovilli
« Reply #18 on: March 12, 2014, 08:58:48 PM »
I feel your pain - wish I were there to help.
Mark
« Reply #19 on: March 12, 2014, 09:00:38 PM »
I'm pretty sure it's not getting fuel.. I will pull the plugs and check as soon as it stops raining/sleeting or as soon as I get it home .. Which ever comes first.
If it has spark & no gas I'll pull the tank and check the filter.
I'm really kicking myself in the ass for taking it for service. I could do everything they did except the ecu stuff.
Now I have to take it apart on my front steps and more or less do it over again.   That's exactly what I was trying to avoid when I took it for service.
« Reply #20 on: March 12, 2014, 09:22:58 PM »
I hope you live in a low crime area , but not wanting to deal with this in freezing rain and wind is understandable .
« Reply #21 on: March 13, 2014, 01:05:50 AM »
Blown off fuel hose in the tank won't trigger a 'Service' warning as it isn't something that the OBD can 'Detect'.
« Reply #22 on: March 13, 2014, 03:01:28 AM »
  To begin with I would remove the fuze from the pigtail just to take that circuit out of the equation. Then go circuit by circuit with a multi meter and test each individually.  If you have a mechanics stethoscope you can touch the probe to each relay while energizing that circuit.  You are listening for the tiny click that the tiny solenoid in the relay makes when it moves.
 I have seen relays too weak to function properly but test okay before you energize them.
Offline molly
« Reply #23 on: March 13, 2014, 05:07:54 AM »
I'm feel your pain on this one for sure. Have you checked the error codes on the dash?
Dave
Lincolnshire, U.K.
Griso 1100
« Reply #24 on: March 13, 2014, 06:52:43 AM »
I don't know how to do this
I will try to search around and figure it out
« Reply #25 on: March 13, 2014, 06:56:02 AM »
There is no fuse in the pigtail.. The mechanic didn't install one because he 'didn't know how many amps my gps was'?
As for the multi-meter I don't have one and I don't know how to use it.
I'll get one and use the manual to try and figure out how to do that if the fuel filter & plumbing all look ok
« Reply #26 on: March 13, 2014, 08:10:47 AM »
One thing for sure - you can quit calling this lemon a "mechanic" ....  :o    2 minutes on the Internet would have given him the answer to that ....
« Reply #27 on: March 13, 2014, 08:14:55 AM »
This really sounds like an electrical connection is:
1. Loose
2. Has a section of bare wire that is shorting on something
biking sailor
« Reply #28 on: March 13, 2014, 08:20:12 AM »
My recomendation.
Step 1.  Turn the ignition switch to the on position with the gas cap open while listening for the fuel pump to work for a few seconds and watch for bubbling/swirling gas (since you just refueled the tank, might be kind of hard to tell).  If you hear the fuel pump run for a few seconds, that is good and you know it is getting a proper signal.  If you see gas swirling around, that is a sign of a hose loose on the fuel pump.
Step 2.  Hit the start button and let the ECU cycle all the way through the start sequence (don't turn it back off unless the starter runs for an extended period of time, as it will turn the starter motor something like 4 seconds and quit on its own if the bike does not start).  If no start, pull out a spark plug and check it for being wet with gas.
This will tell you if it is a fuel issue and what I would do first since it is so easy.  The red triangle of death warning that popped up once, if I read/understood your report correctly, could be a nonrelated issue like the oil pressure sending unit not reading properly.
Also, download a PDF of your service manual, Guzzitech has then on-line, and read up on how to enter the diagnostics code and interpret the fault codes, recording them for future reference.  On my Breva, I would periodically clear the codes after recording them to see what popped up once or was a repeat offender that needed attention.
Good luck and wish I was close enough to come help you rescue yor Guzzi.  Note, I've had help pushing a bike up the ramps into my truck from passers by more than once.  Seems most guys would be willing to help if asked, gives them something to tell their friends about later at the bar!   ;-T
« Reply #29 on: March 13, 2014, 08:21:09 AM »
That's for sure.  Even without looking it up, no GPS receiver is going to draw anything in the range of whole amps, so he could have guessed and put in a 2A fuse to protect the wiring.
