Author Topic: Anyone want to try our 8V Norge map?  (Read 74793 times)
« on: April 21, 2014, 11:43:43 PM »
I hit an indicated 200KPH on the coast road today and its turbine smooth all the way from 2,000 to redline and really puts a bee up the Norge's arse!
Re: Anyone want to try our 8V Norge map?
« Reply #1 on: April 22, 2014, 04:47:19 AM »
Apparently not!  :D :D :D
Offline POP0404
« Reply #2 on: April 22, 2014, 05:39:28 AM »
PM sent.
POP0404
Offline Caffeineo
  • Guzzi B00b
« Reply #3 on: April 22, 2014, 08:09:05 AM »
Would this work for a Stelvio? After I get it home I'll give it a go.
Thanks for sharing.  :BEER:
2022 Moto Guzzi V85
2018 Husky 701
2023 Husky TX300
Offline Gootsz
« Reply #4 on: April 22, 2014, 08:41:38 AM »
Micky here. i am getting the tappets updated on the Griso (1/2 warranty that is). How will that effect the map Mark and you see me up with?
I know a little about cam profiles, etc.
Micky
Gootsz
Satellite Beach, FL
2009 GRISO
2014 CUSTOM
1975 BMW R90/6
THERE ARE NO WINNERS IN ROOM FULL OF LOSERS
« Reply #5 on: April 22, 2014, 01:34:47 PM »
Micky
It will work fine. Although the cam profiles are different for flat and roller tappets due to the way they work the actual lift and duration of the valves is identical, or close to, so the engine breathes the same. There are several roller tappet bikes out there running Mark's map with great results.
« Reply #6 on: April 22, 2014, 01:38:35 PM »
At the moment we don't have a Stelvio specific map and there will be differences depending on whether the machine is single O2 or twin O2 and whether it has ABS and/or TC. We just haven't had test mules to try yet.
Offline pauldaytona
    • Paul's fast Guzzi Page
« Reply #7 on: April 22, 2014, 03:07:05 PM »
3 types stelvio
single O2 No ABS or conti ABS (can run Griso map)
single O2 Bosch ABS
Twin O2
First two(small tank) can have same map, only difference is speed sensor calibration, is a setting anyone can change with tunerpro, just see what value is in stock map and put same in new map.  If you hold mouse over the item in tumnerpro, I put in all different values.
Twin O2, is complete different map, all have TC and ABS. Not only known maps are different also much where we don't know what it is.
« Last Edit: April 22, 2014, 03:07:36 PM by pauldaytona »
Paul
Daytona 1225, Stelvio 1151
« Reply #8 on: April 22, 2014, 05:02:26 PM »
Mark APO just pointed out to me that Doug, (WCB.) is testing a 1O2 map in his Stelvio. I'd forgotten about that.
Offline RunnerDude
« Reply #9 on: April 22, 2014, 08:48:42 PM »
I have a Norge. I don't think anything needs to change, but if it does what you say, sure. Does it void my warranty? Is it reversible if I don't like it? How do I do it? How will my MPG change?
« Reply #10 on: April 22, 2014, 09:07:41 PM »
Completely reversible. Just did a run to check economy average speed 100KPH, bit of town, windy country roads around Bungendore with brief blasts up to 160 but mainly at a 'Sensible 110-120 measured fuel 6.1L/100km.
Offline Waltr
    • Europa Macchina
« Reply #11 on: April 22, 2014, 10:05:49 PM »
Is there a way to store the map with Guzzidiag and use at a later time.  I have Guzzidiag up and running but the read and write program I have yet to install.
Is the map for stock exhaust?  I have a 2012, will it work?
www.motoguzzipa.com
2012 Norge
« Reply #12 on: April 22, 2014, 10:55:55 PM »
Get reader up and running and you can store the original map. Using writer you can then either overwrite any other map or simply re-write the original back into your ECU.
« Reply #13 on: April 22, 2014, 11:18:20 PM »
So this map simply tweaks the speedometer to read too high then.
« Reply #14 on: April 23, 2014, 12:02:22 AM »
 :D Actually a stocker will pull 200 easy enough, it was just the 'Fuque me Drunque' rapidity with which it did it and the turbine like smoothness that surprised me.
Offline molly
« Reply #15 on: April 23, 2014, 03:58:30 AM »
Like Pete said it is important that once Guzzidiag is up and running and you decide to change maps that you use the reader to download your map to a PC/laptop for safe keeping. It can easily uploaded back to the bike at a later date if required or may contain certain info like speedo settings that the new map may require.
« Last Edit: April 23, 2014, 03:58:52 AM by molly »
Dave
Lincolnshire, U.K.
Griso 1100
Offline nikwax
« Reply #16 on: April 23, 2014, 02:54:35 PM »
Hmmm, you tempt me greatly (strokes non-existent beard). What OS do I need to run Guzzidiag?
Ah, found the answer. OK, I have my hand half way up. I'll get the cable I need ordered (if anyone can point me to a functional one?)
« Last Edit: April 23, 2014, 02:58:46 PM by nikwax »
2014 Ducati Multistrada GT
Offline Caffeineo
  • Guzzi B00b
« Reply #17 on: April 24, 2014, 09:42:40 AM »
3 types stelvio
single O2 Bosch ABS
Twin O2
Thanks Paul. So it looks like I can run the Griso map.  ;-T
2022 Moto Guzzi V85
2018 Husky 701
2023 Husky TX300
Offline Edo
« Reply #18 on: April 24, 2014, 12:58:30 PM »
Well, I am definitely interested. Just have to get onboard with guzzi.diag. Should only take 10 minutes, maybe 15?
'13 Norge
'00 V11 Sport
'83 1000SP
Milton, Delaware
Offline pauldaytona
« Reply #19 on: April 24, 2014, 01:54:39 PM »
Even Pete can do it, as not computer savy oilhead.  And if you can find youtube, there it has movies from me that show how it works.
« Last Edit: April 24, 2014, 01:55:42 PM by pauldaytona »
Paul
« Reply #20 on: April 24, 2014, 04:58:09 PM »
Yup, really, even ma! I'm about as close to computer illiterate as you can get!
Offline Spuddy
« Reply #21 on: April 24, 2014, 05:43:11 PM »
Wayne O: You ARE a card...
'13 Stelvio NTX
'07 California Vintage
'01 W650
'00 Quota 1100ES + Ural
Offline Waltr
    • Europa Macchina
« Reply #22 on: April 24, 2014, 10:30:43 PM »
  Does this map disable the o2 sensors or just modify the response under light to heavy load?
www.motoguzzipa.com
2012 Norge
beetle
« Reply #23 on: April 25, 2014, 12:53:51 AM »
O2 sensors are disabled. Plus some other tweaks.
Offline nikwax
« Reply #24 on: June 06, 2014, 07:00:57 PM »
PM sent.
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« Reply #25 on: June 06, 2014, 07:04:55 PM »
You have a map for a stock 07 2V Norge??
μολὼν λαβέ-molṑn labé
« Reply #26 on: June 06, 2014, 07:17:01 PM »
Sorry, down the beach this weekend. Last week was a bit hectic and I didn't get round to sending stuff out. Email me via the board so I have an address to send stuff to. Frans, I know you already have....
Offline rdbandkab
« Reply #27 on: June 06, 2014, 08:39:06 PM »
I'm also interested in a map for the Stelvio NTX.   Herky-jerky at around 3000 rpm.
I received my cables, and have saved my stock map to a couple different mediums..
richy
beetle
« Reply #28 on: June 06, 2014, 08:52:43 PM »
Yes. PM me or Pete your email address. Does it have ABS?
beetle
« Reply #29 on: June 06, 2014, 08:55:27 PM »
richy
The 2O2 Stelvio map is still in development. We'll have a test bike soon to finish it off, but in the meantime if you want to try it out , PM me your email address.
