The stepper is not the cause, it just does what the ecu tells it to do. That shutting it off makes a difference just tells us the stepper is opened by the ecu at some moments we don't like. All result of the conditions and parameters the ecu sees. I have it too. But I noticed the clutch switch doesn't do it's work, even when pulled. When at redlight, idle stays high, until I goto nutral. When I goto first gear then again, idle stays down.
Engine still feels busy compared to stock. Stock map was elecric smooth too so not much to compare there.
This has to make me wonder about other aspects of the tune. Bike is stock? No aftermarket bits? Serviced correctly? Only one air bleed open and TB's balanced correctly?Pete
Question on the new map (7F59): is the throttle response more gradual? I think that's what I'm experiencing.
Yes. Throttle correction ramps up from very little at idle to max at around 7% throttle, then tapers off per norm. If you don't like it, I can send you a map with 'normal' correction.
Anybody else getting idle hangs?
I'm away from home for a few days. I'll flick it to you later this week.
