Author Topic: Jetting with open air le mans 1000  (Read 8717 times)
Madkoffe
« on: June 17, 2014, 04:13:23 AM »
Can someone give me the secret jettings on your le mans 1000 with open air?
Dellorto 40.
Re: Jetting with open air le mans 1000
« Reply #1 on: June 17, 2014, 07:19:22 AM »
From the Guzzi stuff files..
Godfrey's LeMans 1000 Jetting
I've received at least 20 requests for a redux of the jetting articles I did on my LeMans 1000 Mk V so I figured I'd re-post them to the list at large. I sent Frank Wedge three of my articles from euro-moto for the MGNOC News and he shortened them by a bit, as I gave him leave to do. Here are the two significant ones (one was more a ride report); I don't have his exact edit.
These articles pertain specifically to the LeMans 1000 big valve motor with 40mm Dell'Ortos. My 850T is bone stock when it comes to jetting and seems to run just fine, so did my 850T-3; I don't have any specific advice to offer on other setups.
Jetting is a fussy, detail-oriented business. To be successful at it, you must understand the factory setup in valve size, port size, cam timing, you must understand the carburetor instruments and how all the different circuits interact, and you must spend time and effort to get them all right by doing objective, careful analyses at each change along the way. There really aren't any short cuts. A dyno can make the job go more quickly as it provides an artificial environment and a quantitative measurement that you can only approximate otherwise, but even a dyno doesn't always give you a 100% proper jetting matrix.
I usually do jetting top down: mains first, needle/needle jet next, idle and idle transition last. The reason is that this is the order of sensitivity ... it's much easier to get the main jet circuit right before you get the needle right and it's similarly of less total importance. Very few people spend much time at full throttle with today's big bore bikes so if it's off by a half step or so it rarely impacts our use of the bike by very much. You just need to proceed this way, using the data from your observations and logic that is required from an understanding of how things work. It's not so complex and magical as it is tedious.
The rewards are definitely worth the effort and expense. Nothing is so satisfying as a motor that works as it ought to, and knowing that you made it so.
Godfrey DiGiorgi -- Kalessin@eWorld.com
January 1996
Subj: GuzzMania: LeMans 1000 jetting
Date: Sun, Nov 12, 1995 12:21 AM EST
I took the LeMans out for a nice 120 mile ride today, kind of getting myself refamiliarized with it again after not riding it for several months and riding the 907IE a lot. The two bikes are worlds apart in response and feel but both have similar ultimate capabilities. The LeMans is essentially a 1970s motorcycle that has been developed to near perfection, the Ducati is a mid-'80s machines which has similarly been developed to a very high specification. They are about as fast as one another but require very different control techniques to obtain the most out of them.
As you may recall, I started fussing with the jetting on the LeMans soon after I got it. The K&Ns that were on it, the US OEM jetting and the stock throttle/carb return springs made forward progress a surging, stumbling mess and I was determined to fix this. People tell me that Dell'Orto PHF/PHM40s are not possible to tune to be smooth across the board. I don't believe it.
I started by obtaining the complete euro-spec jetting from Moto International (different slides, pilots, needles, atomizers, mains and mixture adjustment screws). I also obtained a stock airbox/plenum assembly and a K&N air filter element to go in it from Harpers Moto Guzzi. From Parts is Parts, I received a set of the standard Ducati-style slide return springs which replace the two heavy springs that Moto Guzzi fits.
I got to this point just before the Colorado trip, it was running reasonably well but idle seemed a little weak and it would occasionally spit. Throttle action was improved but not yet at the level I wanted; the trip was coming up so I was out of time. I bagged a batch of alternative jets and took off.
The small transmission leak that had been an occasional annoyance prior to the trip turned into a gusher during the trip. It was the rear transmission seal, pissing trans oil at the rate of 400cc per 700 miles onto the back of the bike. Yuck. Carburetion during the trip worked ok, a little rich at the higher elevations *except* for the idle, which was smooth and stable as could be. Hmmm. As I returned to sea level, I noted that it began to spit and stumble at idle a bit again. Also, I'd get some pinging if I tried to open the throttle too abruptly at any engine speed under 4500 rpm.
I took the bike apart in July to see what it needed. Indeed, there were a number of details to attend to. The oil leak had made a real mess of the bike, vibration and such had loosened the exhaust header bolts and the horns. I decided that while I had it apart I'd fix the annoying niggles and be done with it.
One of the things that I'd been planning to do was to put in timing gears, just like I had on the 850T. But I figured that the LeMans had the late model tensioner and I could put that off for quite a while yet, it only had 22,000 miles on it. Well, discussion with John Hoffman at Cycle Specialties revealed that I was mistaken ... same old shitty chain tensioner as the 850 had had. Grr. I ordered the gears and they arrived quickly. Last Saturday I took the timing cover off and found 3/8" of play in the timing chain. Looking at the timing marks, it was obvious that the valve timing had become retarded by several degrees. So that's a likely cause for the detonation problem.
Gears went in easily, the fancy external filter sump and lightened flywheel, etc were all assembled into the bike. The trans seal was replaced easily.
Next mod was the throttle itself. I ordered a set of LeMans I race kit throttle cables (for 40mm vs 36mm carbs) and a used Ducati 900SS start/kill switch from Cycle Specialties. From Parts is Parts, I obtained a black finish, Tomaselli Daytona-2C throttle assembly. The Ducati switch requires a little rewiring to mate with the Guzzi harness and the master cylinder needs to move up the right hand bar by 8mm to fit the new switch and throttle. Cables route easily, the inner RH fairing panel is discarded to allow space for the cable runs. Looks factory and fits beautifully. I reset the ignition timing and balanced the carbs with vacuum sticks. Also upped the idle jet to #62s, which seemed to cure much of the idle-spitting.
On my test ride today, there was still trailing throttle backfires and a little bit of spitting. Chatted with Dale about it and he felt that it was still too lean. So this evening I upped idle jets to #65. Idle mixture screws are at just barely 1/2 turn from lightly seated.
No more spitting; stable, lo rpm idle. Idle to off idle transition seems smoother too. Satori.
For the benefit of others who might want/need to get their LM 1000s running right (includes early 1000S models with 40mm carbs and big valve heads), here's my setup:
Final jetting setup
Stock airbox, K&N filter elementStock header pipes and crossover, LaFranconi Competizione silencers
Needle:   K19 - 3rd notch
Needle Jet:   AB268
Main Jet:   150
Idle Jet:   65
Slide:   60/5
Euro idle mixture adjustment screws, 1/2 turn out
It starts easier, warms and idles almost instantly, and is smoother all the way around with a big, fat midrange now. Throttle effort, while not light and soft, is at a very good level with perfect, linear action and response. 40mm Dell'Ortos can work extremely well if you are fussy enough, I guess, and they don't have to cause you tendonitis to use them.
Godfrey
Subj: GuzzMania: more jetting follies
Date: Mon, Nov 27, 1995 11:01 AM EST
I'm at the "extremely fussy" end of jetting now. I really am getting to the very very end of it, finally. I'm determined that these 40mm Dell'Ortos will work correctly.
The last jetting setup worked very well. However, in the course of the past two weeks and a nice leisurely 400 mile bimble this weekend, I noted a small small off-idle spit/stumble and a bit of backfiring which troubled me. Analyzing throttle position/behavior carefully, I became convinced that the problem was too lean a slide cutaway. Since I had them to work with, I swapped in #50/3 slides and rebalanced the carbs when I changed the engine oil and filter. It ran well but lots of deceleration backfiring.
I looked for air leaks and thought about it carefully. No air leaks, hmm, well, this last change had me dropping the idle mixture screws to nearly closed to get a good idle. I suspected the idle jets were too rich at this point; I had likely overcompensated for a lean slide with too rich a pilot jet. So I swapped in #60 idle jets, which cured backfiring and returned the idle mixture screws to 1/2 turn out for a good idle.
LeMans 1000 Mk V jetting setup, mark 11...
Needle Jet:   AB268
Main Jet:   150
Idle Jet:   60
Slide:   50/3
Best throttle response, idle, off idle response yet. I might yet try the #57 pilot jets again as they should put the idle mixture screw out another 1/8 turn which would be ideal. And now I think I can drop the idle even a little more to a nice, smooth 900-1000 rpm tickover.
By the way, for those swapping to timing gears: I made a mistake when I first put the gears in. Without thinking, I put in my usual Torco 20w50 semi-synthetic oil. The gears had quieted down reasonably nicely over the first 800 miles and then stabilized into a light, ringing whirr. When I changed the oil yesterday, I realized my error and used plain Castrol GTX 10w40 instead. I noticed in the short 30-40 miles that I rode the bike yesterday in the course of this latest jetting trim change that the gears had quieted down even more. So if you're putting the gears in for the first time, do use non-synthetic oil to break them in.
I must also say that the G&G external filter/deep sump met my expectations handsomely too. Changing the oil and filter took all of 10 minutes and spilled nary a drop of oil anywhere, a marked improvement from the royal pain in the butt that the OEM filter arrangement offers.
Godfrey
and.....
Quote from: ed@guzzitech.com on July 22, 2011, 08:09:57 PM
The rich running comes from terrible stock jetting. Euro jetting is terrible as well.
I have a jetting recipe to fix these bikes.
K4 needle, bottom clip
128 mains
68 idle
50/3 slide
265 atomizers
The most important thing is the atomizer and needle combo.  Good luck.
Ed Milich
Ed, I found your LMIV jetting page a couple of years ago and rejetted my LMIV to match.  What a difference over stock jetting or the mess I'd backed myself into trying to sort it out.  I was living at about 2,000' altitude at the time, now I'm back about 300'.  Not much adjustment needed so I'm leaving it alone.  Plugs are still a light to medium brown and it pulls hard all the way up the tach.
Thanks!
Tobit
    Re: carb question and advice « Reply #3 on: Today at 04:18:32 PM »    Reply Quote
Forget abot RPM. That has zero relevance. What is important is the throttle opening.
The mixture screws ONLY effect the mix at IDLE nowhere else. If it's idling OK then they are close to right.
Closed to one eighth- Pilot circuit- pilot jet and screw.
1/8-1/4 slide cutaway, although the cutaway works higher than this it is in this range it is the MAIN contributor.
1/4-7/8ths needle and atomiser.
7/8th-WFO manifold depression and main jet.
Albert Einstein
Offline Tobit
« Reply #2 on: June 17, 2014, 09:08:56 AM »
After years of "good enough" jetting on my LeMans IV I stumbled across Ed's webpage, referenced above and used his experience as a starting point.  It was night and day.  The transformation was literally an eye-opener.  The only tweaks I've made are in needle clip height but that's so minor that I probably took a step in the wrong direction and can't tell.
Go to MGcycles.com, order everything on Ed's list that you don't have in your carbs, set your ignition and valve lash and go from there.
 ;-T
Roman, '86 LM IV
Offline Mark West
« Reply #3 on: June 17, 2014, 10:09:51 AM »
I also used a slight variation of Ed Milich's jetting. A huge improvement over the Euro Jetting. A good idea would be to download the Delorto manual, which I think is on thisoldtractor.com and read it thoroughly. That will give you some knowledge to tweak it yourself. It doesn't take long to change jets and needle settings so you can pick up an assortment of bits and find what works best for you.
Mark West
Hollister, CA
MGNOC L-752
Offline Greg Field
  • The Signs Foretell the Rise of a Guzzi Lama . . .
« Reply #4 on: June 17, 2014, 04:44:09 PM »
Favor Ed's over Godfrey's.
That said, there are many combos of jets and needles that will achieve essentially the same result. That said, each combination optimizes smoothness and hard acceleration in a particular RPM band.
I have my own, but I might favor smoothness and roartiness in a different range than you do.
Offline guzziart
« Reply #5 on: June 18, 2014, 07:55:53 PM »
Hey Madkoffe, I did the Ed Milich recipe route on my SE, what a difference, it runs great as a result!  One of the best things I did for that amazing machine was reach out to Mr. Milich for his advice on this subject.
K4 needle, bottom clip....but I think I may have moved it up a notch...don't recall.
128 mains
68 idle
50/3 slide
265 atomizers
Idle mixture screw is 1 1/2 turns out
I got the SE with aftermarket pod filters that wouldn't filter out anything smaller than a golf ball,  I replaced them with K & N's. I installed Delrin manifolds to better support the carbs vs. the OE rubber manifolds and probably aids in setting/maintaining the carb sync. The Delrin addition resulted in having to relocate the enrichener lever assembly...not a problem
However, all the above was done after I had performed "age related" routine maintenance (re-torque heads, valve clearance adj., fresh points/condensors, dist. advance springs, ign. timing, fresh plugs, wires & caps and put the ign coils on a relay instead of handlebar "kill' sw.).
Anyway, that's my $0.02 worth, Good Luck & Enjoy!
Art
PS - I also installed an "eager beaver" headlight relay kit and  "Superbright" brand LED s/t lights, now I don't have to be home before dark!
'71 CB350, '72 Eldo, '72 CL350, '81 CB125s, '87 LMIVSE, '91 CT70, '03 V11 Lemans, '08 Wing  ('12 Wee Strom - R.I.P.)
Madkoffe
« Reply #6 on: June 19, 2014, 07:51:36 AM »
Thanks all for the info!
Online lazlokovacs
« Reply #7 on: February 28, 2015, 01:34:08 PM »
FWIW Godfrey's jetting has worked well for me...
Lemans V
guznax
« Reply #8 on: September 13, 2015, 07:38:48 AM »
Hi,
I'm thinking of changing the carb jetting to the Ed Milch setting as well, because I'm not satisfied about my fuel consumption which is about 35-40 depending on the temperature outside. and there is a sputter between 2000-3000 rpm
My setting today is:
Atomizer AB 208
Main jet 160
Idle jet 60
Needle K19, 3rd notch
gasslide 60/5 (euro)
what is your fuel consumption after his setting?
regards,
Xander, Holland
Offline DavidEJM
« Reply #9 on: June 03, 2017, 02:53:44 PM »
Hi guys, sorry to dig this up from so long ago.
I've just done the Ed Milich recommended reject specs on a guzzi bitsa I bought which believe has a LeMans IV engine in an SPII base Cafe Racer. I have e to say the t seems to ride much better through the range but the main jet feels too small. The engine is crisp though the rev range and then on full throttle it seems to bog down.
I should say that the reason for the rejet was that the bike kept fouling plugs and misfiring so, since everything else seemed to be working properly and set as it should I thought I'd look at the carbs as the bike felt 'woolly' when revved. It all seems to have worked other than at wide open throttle.
Any one else experienced this?
Offline guzziart
« Reply #10 on: June 04, 2017, 06:13:01 AM »
I used Ed's recipe in my Lemans several years ago, the difference was like night and day....the bike runs great.  However, according to the air/fuel ratio meter, it runs a little rich but the plug chops look good too, one of these years I may dig back into the carbs to "fine " tune but for the time being I'm satisfied with the performance.
FWIW, I'm running K & N's.
Art
Online Groover
    • Scooteropolis
« Reply #11 on: June 04, 2017, 08:42:19 AM »
Great replies! Nice bike too!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Online spmoto
« Reply #12 on: June 04, 2017, 11:00:54 AM »
This thread couldn't have come along at a better time for me. My, new to me, LM V has stock US jetting and runs pretty decent except for a lot of popping on trailing throttle and the plugs are almost white. I got the bike from I guy who lived at high altitude so the leanness was probably fine there.
My question is this: Has anyone run Ed Milich's set up with stock intake and exhaust? Do you not what it was designed for? Also, there's no mention of which mixture screw he uses, US or Euro, does it matter?
Thanks,
Steve
Online lazlokovacs
« Reply #13 on: April 26, 2018, 03:38:41 PM »
diggin up an old topic but....
do you think ed had the accel pumpers disabled on his set up? Wouldn't that affect his jetting recipe?
Offline notbent
« Reply #14 on: September 22, 2018, 11:34:15 PM »
Re-digging this thread
I'm jetting my new PHM40's on a '91 LMV
What does 'open air' in the thread title mean?
I have standard airbox, standard crossover and Keihin mufflers.
Cheers, Andy
Offline Turin
    • crap and stuff
« Reply #15 on: September 23, 2018, 02:46:37 AM »
Open air usually means individual pod filters.
1985 Sidlow Guzzi
1996 Triumph Daytona 1200
1996 Triumph Daytona 900
Offline Old Jock
« Reply #16 on: September 23, 2018, 03:17:35 AM »
I changed my LM 1000 to Ed's setup too
Absolutely night and day, the bike would never idle right and plug chops always showed it way rich, I went to Ed's setup and could not believe the difference. To be fair I haven't done a lot of miles but the bike feels so much better, it's like a different engine.
I put up with the old set up for years, I think a PO had tinkered with it and the mains were way too big and the idle way too small, I just could not believe the difference that correct or close to correct jetting can make.
A lot complain that the main jet setting is a bit on the small side, if it is I'll just go up a size or too.
Ed's recommendation is based on a fairly free flowing filter and exhaust. Generally I take that as Turin stated, pods (foam or paper), or a standard box with a performance filter and an aftermarket or gutted silencer. I run foam filters and Supertrapps with about 14 discs as I recall
