I go for a biopsy next week, my PSA has been slowly rising and is up to 5.4 now. I'm just concerned now with how bad the biopsy will be. :-\
My PSA numbers have slowly risen to 7.6 these past several years. A biopsy showed 4 cores positive for Gleason 6 and Gleason 7 cancer. The doctors are recommending Intensity Modulated Radiation Therapy (external beam therapy). Have any of you had any experience with this therapy and what was the outcome. Thanks. :BEER:Matt
I had a very low PSA score but the Dr. found a problem with digital exam. That always seems to work. Had prostate remove 12 years ago, still showing zero on PSA test last year. Not going to have another PSA test done ever.
Matt,when I got diagnosed 10 years ago, I was 50 and my Gleason scores were very similar to yours. What your doctors should have been concerned is the "doubling velocity" of your PSA scores. If the number doubled in value in a year, the odds are that the cancer is aggressive enough to be treated.The choice of treatment should be decided only by you after obtaining enough info about your situation. This means that you should absolutely seek a second, or even third opinion before you decide on your treatment, or even to consider "active surveillance" instead of treatment.Has your cancer metastasized (expanded) beyond the prostate edges already? in this case, surgical removal is probably advisable, with possible radiation later if the PSA readings show a tendency to rise following surgery.Mine was right at the edge, and just to be sure, I had it removed. I fired a couple of urologists before I decided who was going to treat me. Realize now that there are 3 flavors of oncologists out there: radiation oncologists want to nuke you in different ways (including IMRT), surgical oncologists live by the knife and want to cut you open, while medical oncologists want to treat you with poisons. No matter what treatment you choose, they all have side effects. As of today, I have not had any detectable PSA readings. Your numbers are not high enough right now to rush to immediate treatment.I highly recommend you carefully read the book "A Primer on Prostate Cancer: The Empowered Patient's Guide " by Dr. Stephen B. Strum, Donna Pogliano before you consult other doctors. Wishing you the best, and keep us posted.... we are all pulling for ya...Val Barone
Yes, it was a 12 core biopsy with four of the samples positive. The values were 3,3,3 and 4. Not sure I understand the system. The cancer appears to be restricted to the prostate. Digital exams have, over the years, reviled nothing amiss. Currently, at the recommendation of a friend with many years in the medical profession and my primary care physician we are seeking a second opinion. Also my prostate is 58 grams(?) where normal is about 30 making it to large for seeds without shrinking the prostate first. Active surveillance is a consideration but the G 7 presents a concern. The current physician has ruled out surgery. I'll make a decision sometime this winter. One of the guys I have ridden with when I visit in Texas was diagnosed with prostate cancer 15 years ago. He is 92 and still riding. :BEER:Matt
This discussion has been very informative. Thank you.My primary care guy is the one pushing for a second opinion. So far three doctors have given me the "finger wave" exam and found nothing wrong. However lab results don't lie.Son in law called and is going to meet me at TWO for the GA Rally and then it's off to Canada. Then it's time for Barbers Vintage Meet. After that we will be doing Swamp Scooters in November-and then- I hope I have all the information I will need to make a decision-or-be totally confused. :BEER:Matt
Might be worth your time to go to this site and review some of the dozens of medical journals on the causes of prostate issues, and the alternatives to radiation, chemicals, and cutting. Information is a powerful weapon, and there is more than you would think outside the typical range of therapies offered. You can do many things to help yourself the doctor will not share with you. Good luck.http://nutritionfacts.org/topics/prostate-cancer/
I, for one, will definitely be taking a look at that. I don't have cancer, but I'm concerned. My prostate is roughly twice the normal size and in three consecutive tests, my PSA went from 3.5 to 6 to 10. I've had two of the 12-core biopsies, one when it was 6 and another when it was 10, and they didn't find cancer in any of them, but obviously I find all of this pretty troubling. The doctor started me on Avodart about six months ago and my prostate has shrunk some and my PSA was down to 4.5 at the last test. If there are things I can do to help, I'm all over them.
. I have read that in Europe PSA scores don't carry the weight they do in this country. The finger of a skilled doctor is very valuable
