Author Topic: Light flywheel to fit a LM2.  (Read 10784 times)
Offline Stevex
« on: September 11, 2014, 12:04:38 PM »
From the information I've managed to gather so far, the lightest flywheel I can fit to my LM2 is the 10 spring from a V11 Sport.
Is this correct, and if so, is this same flywheel fitted to any other models?
Thanks.
kidneb
Re: Light flywheel to fit a LM2.
« Reply #1 on: September 11, 2014, 12:51:45 PM »
Offline Aldo
« Reply #2 on: September 11, 2014, 12:56:08 PM »
For a LeMans II, you'll need the 8-spring ergal flyhweel like this:  http://www.mgcycle.com/index.php?main_page=product_info&cPath=193&products_id=3335
I've had one in my round head special for 18+ years with zero issues...lightest flywheel in existance for 8-springer's as far as I'm aware...
cheers, Aldo
« Last Edit: September 11, 2014, 01:12:47 PM by Aldo »
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Offline Stevex
« Reply #3 on: September 11, 2014, 01:54:54 PM »
I'm guessing Ergal are aluminium alloy, but anyway I can't justify buying at those sort of prices. I'm not after racing performance, just better response to the throttle and a quicker wind up. I've read that 10 spring flywheels will fit the older models, obviously the spring back plate will be needed too, (will an original 8 spring 2 plate clutch fit the 10 spring?), I've already fitted a deep spline hub.
I should have worded my original question to say the lightest Moto Guzzi flywheel.
I've seen that HMB in Germany charge Euro 249 to lighten the original flywheel and ring gear, maybe that's the way to go.
« Last Edit: September 11, 2014, 01:57:44 PM by Stevex »
Offline Pancake
    • www.dominicsnow.com
« Reply #4 on: September 11, 2014, 03:18:07 PM »
I'd be interested yo know how that goes if you do it. Keep us posted on the results too.
May all beings be happy
« Reply #5 on: September 11, 2014, 03:29:02 PM »
Friction plates are the same for both the 8 spring and 10 spring.
Another source I have seen mentioned: http://guzzipower.com/store/Flywheellightening.html
Offline guzziownr
« Reply #6 on: September 11, 2014, 08:03:37 PM »
I have a lightened flywheel and ring gear from Ed Millich.  It is a stock unit that has been CNC machined.  I put heavier springs from Barnett in as well.  If I had it to do over I would go with the ten springer.  One came up on Ebay shortly after I purchased my wallet-lightening unit.  Light weight, less pressure at the clutch lever and stock Guzzi parts.
Offline jrt
« Reply #7 on: September 11, 2014, 08:10:02 PM »
Why not a RAM clutch?  They are pretty light- it's what I have in my Eldo.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Offline Aldo
« Reply #8 on: September 11, 2014, 11:53:17 PM »
Check with Reboot Guzzi Spares too...they used to do lightened flywheels.  I had one done up by them for my old T3 when I was living in the UK.
http://www.rebootguzzispares.com/
1973 Eldorado 850
Offline arveno
    • ddleathers.com
Offline Stevex
« Reply #10 on: September 12, 2014, 09:25:48 AM »
Excellent, thanks Charlie.
I've been in touch with Reboot and they have a Norge 10 spring flywheel and ring gear.
However, looking at Stein Dinse' online parts catalogue, it shows both the 850 and 1200 Norge as having 8 spring flywheels.
Can anyone tell me if Norge's did have 10 springs fitted and whether this will be the same as fitted to the V11 Sport, or heavier.
They have also said I will need the later type clutch centre; is this the component the clutch push rod contacts?
Will the ring gear from an 8 spring also fit a 10 spring?
Are the 8 and 10 spring clutch push rods the same length?
« Last Edit: September 12, 2014, 09:57:34 AM by Stevex »
guzzigray
« Reply #11 on: September 12, 2014, 10:35:11 AM »
Any 2V 10 spring clutch will work but only as a complete unit (flywheel, pressure plate and ring gear) 8 spring ring gear won't work on a 10 spring flywheel. I have a 10 spring clutch from a Sport 1200 2V and it's very similar in weight to a 10 spring V11 clutch which is very similar in weight to a heavily lightened 8 spring clutch………
The push rod cup thingy are interchangeable and you use the Lemans push rod. 10 spring clutches with 6 speed gearboxes use a different pushrod.
Offline Stevex
« Reply #12 on: September 12, 2014, 12:17:01 PM »
Everything I needed to know, many thanks.
Offline Stevex
« Reply #13 on: December 03, 2014, 01:38:59 PM »
I found a couple of 10 spring flywheels for sale but neither had pressure plates or ring gears.
An Ergal would have been nice but cost wise I decided to lighten the original flywheel.
I sent my flywheel / ring gear to HMB-Guzzi in Germany and they sent me a lightened / balanced assembly in exchange.
The originals weighed in at 5.6Kg, the lightened ones 3.0Kg.
Offline Pancake
« Reply #14 on: December 05, 2014, 02:37:24 PM »
It looks great, how much was it?
Offline Stevex
« Reply #15 on: April 03, 2015, 09:17:29 AM »
Pancake, sorry must have missed your question.
Cost is 270 Euro with your flywheel / ring gear as exchange items. Bargain with the exchange rate as it is now.
« Last Edit: April 03, 2015, 03:55:16 PM by Stevex »
