Author Topic: 2015 Moto Guzzi V7 II merged threadfest  (Read 190984 times)
Re: 2015 Moto Guzzi V7 II merged threadfest
« Reply #30 on: September 26, 2014, 02:46:31 AM »
Now if they take that motive package, couple it with a reactive rear end and put it in a mini Stelvio I'll be all over it like a rash!!! 8)
Offline not-fishing
« Reply #31 on: September 26, 2014, 03:27:15 AM »
This is good news.
Good news for me as the used price in old V7's will drop as people sell them to get the newfangled V7's.  I have lust for an older V7 to convert to a Scrambler
Still I wonder if the "traction control" is not just one more thing to go wrong?  As in water in a sensor wire connection - sound familiar?
Griso 1100
Rosso Corsa Lemans
1/2 a V50 III (with my son)
Offline Dogwalker
« Reply #32 on: September 26, 2014, 06:32:22 AM »
http://www.motociclismo.it/moto-guzzi-v7-ii-arrivano-l-abs-e-il-controllo-di-trazione-moto-59770
"Tenendo a precisare che il grosso delle novità sarà presentato a Eicma (6-9 novembre), Moto Guzzi anticipa i tempi regalandoci un’anteprima delle moto 2015 che invece debutteranno a Colonia"
Pointing out that the bulk of the novelities will be still presented at EICMA (6-9 November), Moto Guzzi, in Cologne, is giving us a preview of the bike that will debut in 2015.
« Reply #33 on: September 26, 2014, 06:33:05 AM »
This is good news.
All the electrical gim crackery is just something to go wrong that I can't fix. <snapping suspenders> And.. unless you have a very good Guzzi dealer, he won't be able to fix it either. The only problems I had with the Norge were the stupid ABS brakes and computerized dash. No thanks. <tamping corncob pipe>
Albert Einstein
Offline drlapo
« Reply #35 on: September 26, 2014, 07:24:35 AM »
the value of my 13 V7 special just went up as folks will now want one of the older, simpler and therefore more reliable models
« Reply #36 on: September 26, 2014, 07:43:31 AM »
Gearbox comparison. Above the old one, in the middle the new one, below that of the California 1400.
Uh, both the V7 ones look the same to me.
I'll take $15k for my 2013 Racer.    ;)
This is the very desirable, uber-reliable pre-ABS, pre Traction Control model.
It also has desirable modifications, such as V7 Stone cast alloy wheels w/ tubeless tires, and a sump extender.    ;-T
Offline Dogwalker
« Reply #37 on: September 26, 2014, 07:52:14 AM »
the new one is more extended in height. Above, you can see the old one is as high than the solenoid. The new one is higher. Below, the new one goes much further down in respect than the starter engine.
Offline roadscum
« Reply #38 on: September 26, 2014, 08:37:13 AM »
Sadly, that's not how it works..  ::)
Improvements of this scope for Moto Guzzi are not evolutionary, they are revolutionary!   ;-T
I hope they step up and improve the suspension as well.
Can someone explain the "engine rotated forward" thing, I'm not getting it???
Paul
« Last Edit: September 26, 2014, 08:40:17 AM by roadscum »
"The only true wisdom is in knowing you know nothing " - Socrates
Paul M. in SW Florida: 318 miles, 11 curves and not a Guzzi dealer in sight!
Offline Phang
« Reply #39 on: September 26, 2014, 08:39:44 AM »
I think that difference is due to the parallax error from different camera heights.
The old engine photo shot with camera at the same height and square to the engine.
The new bike photo took from a higher camera position, about the same height as the Aquila on the fuel tank. You can see the top side of the swing arm all the way to the right from this angle.
2000 V11 Sport (Green)
1973 V7 Sport (Green)
Offline Dogwalker
« Reply #40 on: September 26, 2014, 08:51:01 AM »
From the same angle, the gearbox still seems higher.
Offline Phang
« Reply #41 on: September 26, 2014, 08:56:11 AM »
Paul
Take a look at the photos above  ;D
Offline Phang
« Reply #42 on: September 26, 2014, 09:00:44 AM »
Thanks for posting the comparison photos, the new gearbox sure looks beefier comparing to the old one  ;-T
« Reply #43 on: September 26, 2014, 09:30:35 AM »
Though the Breva/Norge/Griso dashes have me spooked too, it's not like you DON'T have the electrical gim crackery on ANYTHING built today just in the form of the EFI system soooooooooooo... <shrugs>.
Offline Unkept
« Reply #44 on: September 26, 2014, 09:31:39 AM »
I see how they leveled out the engine when you look at the sump alignment to the lower frame rails.
So my wondering is how they received the roughly 1 inch height drop. Probably now that the sump is leveled out and further from the ground they lowered the frame via suspension tweaks?
Regardless, I'm very much in agreement that these changes are on the edge of revolutionary for Guzzi standards. Much like the Carc bikes after the spine frames.
My hope would be along the lines of what Pete said, a mini Stelvio and other models arising using the new transmission and engine designs.
I'd also imagine they would have greatly improved the strength of the transmission... so a new more powerful SB engine top end would probably work great as well.
Love me some Guzzi news.
« Reply #45 on: September 26, 2014, 09:35:39 AM »
Assuming the angles of the photos are about the same, the rotation of the engine jumps out at me.
And what never looked odd to me before on the old one, does somewhat now.
Not that I love mine any less.
Think I'll go ride it!
bpreynolds
« Reply #46 on: September 26, 2014, 09:37:28 AM »
So I love the V7s, okay?  Have almost purchased one on many occasions.  It's a great ride and I personally don't necessarily feel like it needs more power  :beat_horse and such.  But.  I just dunno what to think about this.  Solve or amend the idle issue, yes please.  But traction control and abs in THIS bike is needed or desired?  In a market segment where 2 of the biggest complaints/gripes, valid or not, seem to be "down on power" and price versus the Bonnie?  I mean, I assume these new gadgets are gonna drive the price up, right?  Help me out here, I think it's just my own personal preferences talking maybe.
« Reply #47 on: September 26, 2014, 09:50:04 AM »
Those pics definitely make it very obvious.   If you look at any BMW Airhead, the engine and transmission are at about the same angle.
I assume this is to align the drive shaft with the the output shaft of the transmission.
So, this begs a few questions.   Does M.G. use a CV (constant velocity) joint or U-joint where the drive shaft connects to the transmission.  Operating a U-joint at an angle introduces a torsional vibration in the driveshaft.    If there are two U-joints, at equal and opposite angles, i.e., the final shaft is at the same angle as the input shaft, then this cancels out in the two U-joints.     A CARC or Paralever system would be able to deal with this.
Do we have any pictures that show the (new) rear drive in detail?
I'm going to assume that they're not going to put CARC on it for cost reasons.
« Reply #48 on: September 26, 2014, 10:00:24 AM »
Dude, even the Sportster offers ABS now.
ABS was obviously added because it is soon REQUIRED... and the TC could just go along with the tech. As long as you already have something to monitor wheel speed/slippage, you can easily add that too. Especially if you have a RBW or modified RBW system.
Offline tonUPRacer
    • My Racer FB page
« Reply #49 on: September 26, 2014, 10:05:18 AM »
Those comparison photos really show the change. I wonder if handling is improved at all? I think its kindof funny to have traction control on a 50hp bike, but I guess its what folks expect in a modern bike. I won't be trading in my '13 for a '15.
2013 V7 Racer #393
2001 Ducati 900SS (sold)
1999 Ducati 900M (sold)
1979 HD XLS Sportster (sold)
Cheese
« Reply #50 on: September 26, 2014, 10:19:17 AM »
Appears the lower frame rails are different. Not sure if CV joints can operate at the speeds needed for the driveshaft.
« Reply #51 on: September 26, 2014, 10:37:01 AM »
Lowered swingarm pivot position?
Compare with the front axle position....
More space visible between swingarm and the side panel frame too.
« Last Edit: September 26, 2014, 10:41:39 AM by Penderic »
« Reply #52 on: September 26, 2014, 10:55:36 AM »
Semi-kinda-sorta-maybe drive-ride by wire, control this and anti that...
Guess that locks up the period of nuevo V-7s in my future:
Single throttle, tanks sorted, no skill crutches installed.
Not for me, I and those like me fear that which is new and unusual. It's all a conspiracy so that the TSA, DHS or FEMA can control my movements.
I'd like to get more into it but I have a dermatologist appointment to address the irritations from the ti-foil between my scalp and helmet liners.
Offline Dogwalker
« Reply #53 on: September 26, 2014, 10:55:59 AM »
Infact. That's possible cause the junction between the gearbox and the driveshaft is lowered in the new gearbox.
You can see that, in the old V7, the swingarm pivot is above the junction line of the two half-blocks of the engine (that you can see under the cylinder), in the new one is below that line.
bpreynolds
« Reply #54 on: September 26, 2014, 10:58:44 AM »
Well again, thanks for pointing that out.  True, I suppose.  And, I guess at least some of the folks are new riders or somewhat new and probably could use the abs as much or more than experienced riders on super fast machines.  Again, as I said, I guess I was thinking more of my own personal preferences.
« Reply #55 on: September 26, 2014, 11:45:44 AM »
Based on recent history, I'm going to guess that the U.S.-bound 2015 bikes are the same as the 2014 bikes and that we get the V7 II for the 2016 model year.
ABS is being added due to an E.U. requirement.   The U.S. doesn't require it yet.
« Last Edit: September 26, 2014, 11:46:41 AM by jas67 »
Offline sib
« Reply #56 on: September 26, 2014, 11:53:56 AM »
I'm interested in what the weight will be.  The ABS/TC will probably add very little weight, but the beefier wet alternator and especially the 6 speed tranny could add significantly.
Looking at the side view comparison, the V7 II engine looks level while the engine of the '13-'14 V7 Stone looks like it's pointing slightly upward toward the front.  I somehow never noticed that on mine.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Online rocker59
« Reply #57 on: September 26, 2014, 12:05:30 PM »
You can thank the EU for mandatory ABS.
2004 California EV Touring II
Offline roadscum
« Reply #58 on: September 26, 2014, 12:07:21 PM »
 :winer
Ahhhh, now it get it, and I like what I see.
Paul
« Reply #59 on: September 26, 2014, 12:16:19 PM »
The lack of passenger grab rails lighten it a bit.  ;)
