Whip off a rocker cover and make sure they have snapped the tops off the adjusters. If they haven't then the tops of the adjusters bash on the rocker covers.
That would simply wreck my day.
:D :D :D :D :D Yeah , and where is our update Rico , if your name really is Rico :D Around here , we expect answers ;D Dusty
Thats right, Dusty, you tell Rico the way we roll around these parts! We not only want answers, but pictures too! ;DRick.
So I just got the recall done at a new moto guzzi dealership. I was pleased with them, and it seems like they actually did all the work they were supposed to.
I found out that the Jax dealer charged guzzi for the recall and just gave the bike back to the owner without even pulling the valve cover.
All this is very unfortunate. We are waiting for a set of tools to complete this job on a bike we have in the shop now. Piaggo ponied up and is paying for this bike to get it done. Looking through the service procedure the job is not exactly a walk in the park and includes a very detailed explanation on how to clean out the block even if there is no sign of shrapnel.
PS? Why would you claim for the work and then not do it?
I assumed overhauling the engine meant they fixed everything, but unfortunately my mechanical understanding is limited.
The recall kit I purchsed included all of the gaskets, oil filter too if I remember correctly. Not sure this dealer is playing straight with you.
I don't think an air gap is a good check for lash on the hydros. Some lifters will leak off when the engine is off and some won't. That's why you can get a little diesel clatter for a second when you first start the engine. That's normal for some engines.You can still adjust the valves, but it's more of a PITA. To check the lash you remove the rocker assembly, relieve the residual pressure, pull the lifter insert, replace it with a calibrated slug, adjust to the slug, pull the slug, replace the insert, replace the rocker assembly [X no. of valves). During all that, if you need to do an adjustment you can easily work the adjuster post without the screw end attached.But I ask you -- did the dealer check the lash as I described above, or did he wiggle the adjuster with his finger and make some proclamation about it?Anyone thinking that hydraulic valves need regular adjustments like solid ones do is ignorant of the technology and should not be trusted past holding the beer for the guy who knows. I'm not sure you can get a fair compression reading without pumping up the lifters. They need oil pressure to seal. My recall kit included everything but the mechanic to do the work for me -- parts, gaskets, special tools, etc. IIRC, there's a list provided with the kit telling you what all should be in there. I've seen a lot of incomplete kits sold on ebay missing parts, tools, or gaskets and still commanding several X retail $$$. I think someone tried selling some here once.If this outfit 'overhauled' the engine, did you get your old parts back? That's the closest you'll get to 'proof of service'. Ask them specifically if they pulled the oil pump and what condition is it in? The vanes in my pump looked like wire brushes from the chewing they gave all that shrapnel.
He tried to break off the tabs with vise grips, but couldn't do so, so he grabbed an air grinder with a cut off wheel on it and cut off the tabs.
