Author Topic: Le Mans UJ Carrier Bearing - SKF Part Number?  (Read 3625 times)
Offline stuv65
« on: January 27, 2015, 07:53:31 AM »
I have the Guzzi part number for the UJ carrier bearing for my Le Mans Mk 5, but does anyone have the SKF part number please?
ta
stuart
Offline sib
Re: Le Mans UJ Carrier Bearing - SKF Part Number?
« Reply #1 on: January 27, 2015, 09:37:32 AM »
Check out this table at Guzzitech GB:  http://guzzitek.org/tableaux_guides/Roulements_Spis_Toriques_MAJ18.pdf
It cross-references many Guzzi bearing part numbers with SKF numbers.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline Perazzimx14
« Reply #2 on: January 27, 2015, 10:31:16 AM »
Pull the bearing and look on the race for the numbers. Give these numbers to your bearing retailer and tell them you want a SKF bearing to match. If the numbers are not legable measure the OD x ID and thickness and give theses numbers to you bearing retailer.
Numbers will be something like 6206RS (60mm x 30mm x 16mm).  6206 is common within most bearing manufacturers as the "RS",  It stands for "rubber seal"
While your swing arm is out also get the pivot bearing sizes and seal sizes. I can get you the 3 bearings and 2 seals for about $40 USD. Don t know what shipping would be though. Bearings are KOYO.
« Last Edit: January 27, 2015, 10:36:28 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
2016 Suzuki Van Van 200
« Reply #3 on: January 27, 2015, 10:45:35 AM »
Offline Doug McLaren
« Reply #4 on: January 27, 2015, 03:08:11 PM »
Try these fellas Stuart, I've always had good service from them.
http://simplybearings.co.uk/shop/advanced_search_result.php?keywords=6206
2019 V85TT
1994 Ducati 900 Monster
1957 Lodola 175
« Reply #5 on: January 27, 2015, 04:50:35 PM »
Most bearing houses would carry what you need.  The number off the old bearing will work.
From the Deep Deep South out in left field.  There are no stupid questions.  There are however stupid people asking questions.  🤣, this includes me.  😉
Offline stuv65
« Reply #6 on: January 28, 2015, 02:18:22 AM »
Thanks all for the useful comments.
I should have said, from the bearing I removed I could only read "GERMANY"  and "S**" but nothing else.
Thanks again - ta, stuart
« Reply #7 on: January 29, 2015, 12:36:52 AM »
Swedish company that made the bearings in Germany.
