It took me years to find it so maybe this will help someone. This is on PHF 36s from an LMIII, but it seems possible on any similar float. Old style black floats with steel pivot. One float is attached to the steel pivot 2-3mm too close to its axis of rotation. Consequently the float hits part of the carb body when the float level is adjusted correctly. The result was popping through one carb when cold. Does anyone have a good black plastic float they'd like to sell? :BEER:
Charlie, Thanks for the link, but are they the same floats? Mine are marked 7540.1 while the Convert floats in the ad are marked 7480.1 (I think!).
Mine read 10g. I thought the part number was what was cast into the float so unless I copied the number down wrong isn't it a different float?
The eBay floats are from VHBs, but PHFs and VHBs use the same float - same part number.
Matt, the white ones are the sinkers - right?
Mine are. However it is starting to look like I have a fix. Stay tuned. :BEER:Matt
Great. Seems like a dip in some tank sealer would work.Thanks!
Don't be so sure that is the problem. Three times I've seen the "neck" pull away from the body of the float-needle valve. Two were on Guzzis, and the third was on a BMW R90S. Pull both needle valves and compare them against each other and against a known good one. The running condition this causes will drive a person nuts. Been there three times.
I take it Matt's keeping his! ;DThanks,Shawn
Do the older brown plastic floats survive ethanol gas?
All of the original floats "survive" pretty well. A small percentage will eventually fill up with gas, but they did that even before ethanol was added to the fuel.
