Thanks for the warm welcome.I bought the bike running, but last time I tried to fire it up it didn't want to any more. I've tried a lot by now and it doesn't want to start, does anyone have tips or advice to get it going again?The bike is partly stripped, and the electronics were a mess, half of the wires are changed for red, grey or black ones and wire are twisted together instead of soldered.
Referencing the drawing Chuck attachedLook for 12 Volts at the common Red between the two coils (26)If it's ok there check the common Red for each module (27)Spend some time around the coils and modules making the wires secure there it will be time well spent.If you don't have 12V at (26) work your way backwards following the white wire trail thru the kill switch, to ignition switch.Might I suggest adding a large in line fuse (40 Amps) at the battery where all the red wires take off, with all the bodgie wiring it willblow if you get a short rather than set the bike on fire.
So, I'll make a quick list1) there already is a 40Amp fuse at the battery ;-T2) Mine doesn't have a module, V65 is a slightly different elec. diagramhttps://s-media-cache-ak0.pinimg.com/originals/7e/9a/10/7e9a10893242d1577f84ca40671dead5.jpg3) I measured current coming from the ignition switch and going to the rotor. On the right side they're the same, but on the left side 12V arrives but only 1.2V goes to the rotor. Soooooo, yeah I don't really know. Help please.4) next I checked the resistances with my ohm-meter: right 36ohms, left 31ohms. This might be because the coils are different because one was recently changed.I won't be working on it untill next week, I'm hoping for answers mean time.Thanks for all your help so farExtra: I came across a 750block for little cash. Since my insurance company wants to keep the frame and engine numbers matching I was thinking of fitting the 650block with the 750 cranck, pistons, cilinders, heads and cam. Is this possible?? Preferably none to little modifications, I already checked bearing numbers and they match.
Also replacing 650 internals with 750 parts may require a change to the ignition and charging systems as I doubt they are the same and the cam and crank shape will probably be different. Difficult to be specific without exact model info but, more effort than its worth IMHO.
