Author Topic: 2013 V7 Special bar end mirrors  (Read 10962 times)
Offline Buckturgidson
« on: March 20, 2015, 07:10:55 PM »
To my dismay I learned there are inserts in the handlebar that prevent use of plug and play bar ends. They cannot be removed, someone on the forum said they are welded in place, which makes sense considering there is nothing short of a drill to get them out. I cannot believe something as simple as bar ends is such a hassle. Any input would be appreciated.  :beat_horse
"It's not your job to be as confused as Nigel." -Spinal Tap.
"Wagner's music is better than it sounds." -Mark Twain
'24 V100 Mandello, Violetta, bianco polare.
'07 Norge, Rosina, the classy one
Offline drums4money
Re: 2013 V7 Special bar end mirrors
« Reply #1 on: March 20, 2015, 07:31:28 PM »
It might be a less frustrating exercise to just replace the bar. .
Or if the mirror clamps onto the bar, can the controls be moved inboard by 1/3 inch?
I just answered my own question.  If you need to be inside the bar, there's really no easy way around it.
Good luck.
Old School Audio:
Offline drlapo
« Reply #2 on: March 20, 2015, 07:36:07 PM »
I installed Napoleaon bar end mirors on my14 Special without problems, just use a different bolt
« Reply #3 on: March 20, 2015, 07:37:08 PM »
Who is the madman, or A-hole, who decided to weld an insert into the ends of the handlebar? WTF?
Offline drums4money
« Reply #4 on: March 20, 2015, 08:18:01 PM »
The same mad man who loc-tight'd the entire length of threads on mine.  Throttle side came off no problem. Clutch side wouldn't move for heaven or earth.  Then the allen stripped.  Now fully committed I got after it with the universal adjustable locking general purpose wrench with all the effort I could throw at it.  CRG insert incoming.
Old School Audio:
« Reply #5 on: March 20, 2015, 09:25:08 PM »
I am speechless.
guzzipete
« Reply #6 on: March 20, 2015, 11:03:13 PM »
I have Rizoma bar end mirrors on my 2009 V7C.
I took one of the stock bar end weights and a mirror to a machine shop and asked them to make a pair of aluminum bar ends that fit the Rizoma mirrors and looked as close to stock as possible. They did a great job. It did cost me $100, but at the time there were no other options that I could find. I think that Rizoma now makes bar end adapters that will work the V7 handlebars.
Here is a link to pictures of my bike.
http://wildguzzi.com/forum/index.php?topic=24043.0
Offline Moto Fugazzi
    • Griso
« Reply #7 on: March 20, 2015, 11:04:34 PM »
Use those inserts to your advantage! Use a different bolt if needed, but you won't find a more solid mount than welded inserts if you can make them work. I used a longer bolt on mine, and sandwiched my CRG type bar end mirrors between the bars and the bar end weights.
Worst case, you can buy new bars for under $25 and make the bike your own. You will have to drill holes for the controls, but it's not difficult at all.
Ken
Check this thread: http://wildguzzi.com/forum/index.php?topic=68671.0
« Last Edit: March 20, 2015, 11:15:34 PM by Moto Fugazzi »
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
Offline roofus
« Reply #8 on: March 21, 2015, 09:50:37 AM »
Offline Zinfan
« Reply #9 on: March 21, 2015, 08:43:46 PM »
I used these http://www.rhinomoto.com/bar-end-sliders.html on my V7 Stone along with CRG Arrow mirrors.
edited to add, I got the ones with the groove in them of course, not sure what mirrors you are planning to use but the CRG's fit fine.
« Last Edit: March 21, 2015, 08:48:45 PM by Zinfan »
Offline malik
« Reply #10 on: March 22, 2015, 04:03:08 AM »
Corsa Italiana sell these:
http://www.corsaspeedshop.com/epages/yp3bcw66xzdr.sf/en_GB/?ObjectPath=/Shops/yp3bcw66xzdr/Categories/Guzzi_V7_Stuff
but you can get the bar ends by themselves. It may be cheaper for you to have some helpful local turn something up, or even cut a groove in the originals. If you want close-up photos of the Corsa ones, just let me know.
When I had the standard bars, I used the CRG standard type, but cut the insert off - worked well. I believe they did, at one stage anyway, have flat versions for our guzzis.
Mal
« Reply #11 on: March 22, 2015, 08:34:33 AM »
Those are perfect, wonder if anyone has them stateside.
Mal
Offline rbm
« Reply #12 on: March 22, 2015, 08:48:47 AM »
I bought the Corsa Italiana barends referenced below for my V7 from Corsa Meccanica in Toronto.  If they stock them, there is high chance other shops in the USA stock them.  Worst case, order a pair from Corsa Meccanica.
- Robert
2011 Moto Guzzi V7 Racer
