4.5, 4.25, 3.0 (inches)
why all the fuss. change the oil, put in the proscribed amount, and then see where the oil level is on your stick, and mark it. you could even mark it so you could measure on the side stand, or screwed in or not screwed in... your choice... just recently changed the oil, and don't want to change it to do this "trick". ask your self these questions, does your bike smoke, does it require oil between changes, does it leak? If you can answer no to all of those, then you can do the "trick" right now...
