Author Topic: Added LED rear light- Norge  (Read 8803 times)
« on: April 29, 2015, 02:03:13 PM »
I wanted to have an additional light on the rear end of the Norge so I put this on:
Standard running.
Brake light activated
Side view.
These pics all taken in bright daylight.  The standard rear tail lamp on the Norge does nothing to illuminate from the sides.
These are two LED strip lights wired so that the topmost row is always bright and the lower row is dim but glow bright when the brakes are applied. They could easily be wired in any configuration including blinking during braking. They draw very little energy but I think they do provide a standout presence when you are stopped, crossing intersections and so on.
I used the LED lights with a black background so that they blend into the Norge's tail pack carrier. As you can see from the top picture, at off angles the added LEDs really show up whereas you can barely see the stock tail lamp. From the side, no comparison.
I was going to illuminate the assemblies on the tail trunk but I often ride the Norge without it and then means plugging and unplugging it. Not a big hassle to do but this is no hassle.
« Last Edit: April 29, 2015, 02:06:46 PM by Norge Pilot »
cjoles
Re: Added LED rear light- Norge
« Reply #1 on: April 29, 2015, 02:20:18 PM »
Looks great!  I had planned on only having my Givi case on when I needed it but feel that the LED's with brake, taillight and turn signal add so much to my visibility that I've kept the case on for the last year and a half or so full time for the safety aspect.
Offline Idontwantapickle
« Reply #2 on: April 29, 2015, 07:00:29 PM »
That's nice! Where did you get the lights?
Hunter
Sir James Paul McCartney
AMA Charter Life Member
72 Eldo
84 BMW R100RS
Offline Adk.IBO
« Reply #3 on: April 29, 2015, 07:31:45 PM »
Did the same thing with "Admore Lighting" LEDs, been a bit longer than that though. Touch the brakes and tailgaters get the idea.
Luke 23:34
« Reply #4 on: April 29, 2015, 08:25:21 PM »
Pep Boys of all places. I wouldn't have the oil in a sewing machine changed there but they do have a very good selection of those LED strip lights. Get the super brights, they have different item models there. They have batteries connected to them on the rack so you can see which are brightest.
The wiring was pretty straight forward and it was by my one mistake that the top row got wired bright on all the time. In the end I liked it take way because it gets noticed all the time. It seems to keep the sleds back just a little bit more than the stock lamp which unless you are looking directly at it, is almost invisible.
A tip:
While the 3M VHB does stick to the luggage rack very well, I used some black tie straps to make sure nothing was going to come loose. Unless you get real close you can't see them in which case you wouldn't see me standing behind you either.  ;)
Offline JeffOlson
« Reply #5 on: April 29, 2015, 08:53:53 PM »
Very nice! Nimrod cagers should see you better now.
2018 Vespa GTS 300
2016 Moto Guzzi Norge
2015 Vespa Sprint 150
2015 Vespa GTS 300
Far star
« Reply #6 on: April 29, 2015, 11:05:44 PM »
No Pep Boy in Whitehorse however if I ride to WSBK in Laguna Seca I'll find one somewhere.  That and some other coveted Guzzi trinkets. Nice addition to our Norge, I like it.
Offline atavar
« Reply #7 on: April 29, 2015, 11:43:07 PM »
I just ordered the light kit for my Givi E450 topcase.  I'll see how it is when it gets here.  I may end up adding some extra lighting as you have done.
Offline swmckinley54
« Reply #8 on: May 04, 2015, 12:21:17 PM »
P3 lights from Skeene.
Steven Mckinley
Austin, TX
2016 Eldorado
« Reply #9 on: May 04, 2015, 08:34:39 PM »
I've got the smaller Admore on my Breva 1100.    It works well, though it now has a fuel individual LEDs that no longer work :-(
Offline atavar
« Reply #10 on: May 04, 2015, 09:03:46 PM »
OK, i am running in to some minor snags dealing with the Norge active tail light.  Does anyone know a source and maybe part numbers for the Norge tail light 3 pin electrical connectors?  I would like to make an adapter harness and avoid cutting in to the stock harness.
« Reply #11 on: May 04, 2015, 09:26:43 PM »
Superbrightleds
They have a ton of different ones.
My trunk is bolted on so I added a strip under the reflector
« Reply #12 on: May 04, 2015, 11:42:33 PM »
I cut the stock wires, then wired in a split and fused it. Used waterproof heat shrink connectors from a Marine supply shop. If I want to disconnect the LEDs, I can either pull the fuse (also waterproof housing) or disconnect by pulling the pigtail. If there is a fault I can use that split to check to current too.
The LEDs can run off a 9 volt battery so the draw can't be very much.
On the Superbright store. They have a good selection but the one time I ordered a bunch of LEDs (at least 20) for my DP Motorhome (ceiling lamps) and one was DOA, they wanted me to send them back the bad one at my cost in order to get a replacement. Would have cost me more in shipping that it was worth so I stopped buying from them. Besides, you can find equal or better quality a lot of other places.
« Reply #13 on: May 05, 2015, 08:25:08 AM »
I've always had good luck with them.  Tail lights, turn signals, strip lights, license plate lights.
I do buy from the auto parts store if they have what I want.  Like the indicator lights on my dash or the front turn signal lights.
« Reply #14 on: May 05, 2015, 12:40:50 PM »
Atavar, you can always use those splices they sell that don't require cutting wires. They work really well and you can remove them later and just put a piece of silicon tape over the spot where the splice connector used to be:
I think they call them T Tap connectors. HD and Lowes have them. I wouldn't use them for something getting pulled around but for the light kit or leds they should work just fine. I always use some silicon tape around any splice, just cause.
Offline atavar
« Reply #15 on: May 05, 2015, 01:12:15 PM »
Unfortunately to wire in an aux light I need to insert a diode in the brake light wire to block the voltage from the tail light circuit.  That means I have to cut at least one wire.  Those tap connectors are also famous for corroding after a couple years.
Besides which I really prefer being able to go back to stock in case of problems or just because.
Thanks for the idea though.
« Reply #16 on: May 05, 2015, 07:50:45 PM »
Pep boys! Whodathunkit! Thanks.
BTW I have the same tail trunk as you do. I would love to illuminate those clear red panels on top but they are not up for the job. And if I lose much room inside the lid my fathead helmet might not fit.
Maybe the Italians have a light kit for that.........
Hunter
72 Eldo
84 BMW R100RS
Offline 1Sourdough
« Reply #17 on: May 05, 2015, 10:44:26 PM »
Superbright and other venders have LED flashers, too.  I mounted a small LED strip on the license mount below the taillight and a unit inside the box to which the taillight is attached which flashes four times fast, four slow and then stays on.  Since the LED unit is an auxiliary, not the official brake light, it's OK to flash
1993 Strada 1000, 1996 R1100RT, 1999 V11 EV
                            -30-
