Author Topic: lean-burn carbs?  (Read 5164 times)
Offline lazlokovacs
lean-burn carbs?
« on: May 28, 2015, 07:08:23 PM »
can anyone confirm if these are lean-burn carbs?
and if so, how does one change that high brass insert for a normal one??
thanks as ever
Re: lean-burn carbs?
« Reply #1 on: May 28, 2015, 07:15:40 PM »
A taller primary choke height makes a richer midrange mixture.  Assuming you're referring to the shroud around the needle jet, going to a shorter one will make it run leaner.
« Reply #2 on: May 28, 2015, 07:29:43 PM »
Why would you want to change them? Set up correctly the 'Lean Burn' type give crisper performance and use less fuel.
Offline sib
« Reply #3 on: May 28, 2015, 07:42:59 PM »
If I've learned anything on this forum, it's that some folks want to change things just because they can.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
Offline NCAmother
« Reply #4 on: May 28, 2015, 08:02:13 PM »
You're right, but if you never change you never learn.
Howdy
Offline Bisbonian
  • Living the Dream
« Reply #5 on: May 28, 2015, 08:14:07 PM »
I thought this was a diet thread.
Offline jacksonracingcomau
« Reply #6 on: May 28, 2015, 08:21:54 PM »
thanks as ever
Answer is it knocks out , I think Rod (Yak Fat, RIP) did a summary of changes, search on here
But as Pete says, nothing actually wrong with them , my experience with LM 3 (LB PHF 36) over 1 or 2 (old PHF36) is they are only a problem when people put big jets in.
Nice dress
MH
« Last Edit: May 29, 2015, 11:27:51 PM by jacksonracingcomau »
Offline lazlokovacs
« Reply #7 on: May 29, 2015, 03:06:02 AM »
thanks everyone,
original question was 'are these lean-burn carbs'?
anyone got a Y/N answer?
« Reply #8 on: May 29, 2015, 03:30:28 AM »
Yes, they area hat have been described as 'Lean Burn' type. The shroud creates a greater depression around the anulus of the atomiser meaning for any given aperture more fuel will be pushed through from the float bowl.
Offline lazlokovacs
« Reply #9 on: May 29, 2015, 03:42:12 AM »
thanks mate...
Offline sib
« Reply #10 on: May 29, 2015, 06:48:55 AM »
Ah, so THAT'S where the Mystery Pin goes.
Offline mtiberio
    • TiberioRacing
« Reply #11 on: May 29, 2015, 09:44:38 AM »
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline lazlokovacs
« Reply #12 on: May 29, 2015, 12:39:02 PM »
vasco, (or anyone), do these lean-burn carbs require different jetting then? I was planning on using Ed Milich's jetting recipe as a starting point, engine is a lemans 1000 big valve...
^and our current assistant prefers to remain anonymous...
« Reply #13 on: May 29, 2015, 02:10:25 PM »
Almost certainly yes. To the best of my knowledge all big valve 948's came with 'Conventional' carbs but that may not of been true for the U.S. market.
