Author Topic: Iridium plugs for the single TB V7  (Read 4735 times)
Offline pyoungbl
« on: June 12, 2015, 03:58:07 PM »
Nobody lists a cross reference for Iridium plugs in the newer V7.  Turns out the CR8EIB-9 (product 5258) is the one to get.  Expensive as hell so they MUST be better.  Seriously, I have had great results using Iridium plugs in other bikes so thought I'd try them in the baby block.  In the Stelvio I got faster starts, particularly when cold.  She also seemed to run better hot or cold.  It might be my imagination but I think I got slightly better fuel mileage.
Peter Y.
« Last Edit: June 12, 2015, 07:00:58 PM by pyoungbl »
'13 V7 Special (red/white)
Offline Kev m
Re: Iridium plags for the single TB V7
« Reply #1 on: June 12, 2015, 04:09:03 PM »
Let us know what you learn.
« Reply #2 on: June 12, 2015, 04:22:10 PM »
I've used wire electrode plugs in engines that were prone to fouling plugs, and they do seem to resist that somewhat better than standard plugs, but I've never noticed any performance gains, easier starting, or anything like that.
Offline clubman
« Reply #3 on: June 12, 2015, 05:21:38 PM »
Use the Ir. in my V7C, 23K still look like new. Have a set in my Tri. Sprint with 38K same deal. Definitely better cold starting, never noticed better mileage. Try Sparkplugs.com for a more reasonable price. The NGK website will give you correct crossover #'s.
makarushka
« Reply #4 on: June 12, 2015, 06:46:58 PM »
Another option is to swap the spark plug boots for NGK XD05f and use the iridium plugs from Denso, part number IU24 (5632)...
Offline pyoungbl
« Reply #5 on: June 12, 2015, 07:16:04 PM »
Try it...no joy.  The closest thing is what they list as the V 70, 700cc, no plug listed.
Offline kevdog3019
Re: Iridium plugs for the single TB V7
« Reply #6 on: June 12, 2015, 11:16:50 PM »
I like them in the V11 lemans. Better response. The stock Lario didn't notice a difference. Should try in this Lario. I'm curious about your findings. I'm a believer.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline Yukonica
« Reply #7 on: June 13, 2015, 10:58:58 AM »
Triple Jim: "When the Brussels sprout fails to venture from its lair, it is time to roll a beaver up a grassy slope."
Either a closet Canadian slogan or multi-nationalist slur; can't figure which. :)
Personally... I wouldn't dare roll a beaver anywhere. They cut trees down with their teeth.
Headed to town now to see if these plugs are available locally (laughing).
« Reply #8 on: June 13, 2015, 11:14:05 AM »
As I remember, there was a Hot Rod Magazine article back in the '70s, and a race team had some mechanical problems that put them out of the race.  The lesson learned was stated to be "When the Brussels Sprout..."
Offline sib
« Reply #9 on: June 13, 2015, 01:45:48 PM »
Just repeating what I learned on http://advrider.com/forums/showthread.php?t=835438&page=94
The correct NGK plug is CR8EIB-9
Cost about $8 apiece at various online sources.
Current: 2021 V7 Stone E5
Previous: 2016 V7II Stone
Previous: 2013 V7 Stone
