Author Topic: Heel and toe shifter set up for An 850-T without Floorboards…?  (Read 3406 times)
Offline radguzzi
Well the ongoing sage of Frank’s 850-T (with a T-3 filtered engine) goes on.
It is here for new headlight ears and a couple of minor adjustments in the screen that was installed a few months back.
The shifter has long given the rider a hard time due to an issue with pivoting in the ankle, poor guy suffers from gout and when that is not flaring up, arthritis making shifting with the stock 850 lever a real problem.
It finally dawned on my, while looking at the West Coast Guzzi V11 Jackal that a heel and toe shifter is what he needs.
I know that the swap to boards would do it but is there a set up for a heel and toe shifter with pegs ala Bassa, Jackal etc on an earlier Tonti frame.. …?
That would keep me from the need to swap brake levers and all that with swapping to boards.
Thanks,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline mtiberio
    • TiberioRacing
Re: Heel and toe shifter set up for An 850-T without Floorboards�?
« Reply #1 on: November 29, 2015, 07:47:45 PM »
Weld on a heel section
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline JoeW
    • The Guzzi Doctor
« Reply #2 on: November 30, 2015, 08:48:48 AM »
I have the complete lower rails with linkage and pegs from an 03 stone. I would swap you for the stock T setup. Or, sell it outright.
Joe Walano
Re: Heel and toe shifter set up for An 850-T without Floorboards…?
« Reply #3 on: November 30, 2015, 09:56:13 AM »
My Eldorado came with pegs and a heel and toe.
You are right, it is easier as you get older.
As for the gout, tell him to drink lots of water, the crystals form because the  fluids are too concentrated.
« Reply #4 on: November 30, 2015, 11:54:11 AM »
I had a heel and toe shifter on my old CB500-4.  Used the stock shifter and attached a 'heel' section.  Not because of foot problems.  Spit shined boots.  Didn't want to mess them up making upshifts.  :)
FWIW, my heel portion was long and set behind the heel of my boot.  When upshifting, moved the ball of my foot to the peg and the heel rested perfectly on the rear portion of the shift lever.
Offline NCAmother
« Reply #5 on: November 30, 2015, 12:45:02 PM »
Maybe suggest a Convert?
Howdy
Offline radguzzi
« Reply #6 on: November 30, 2015, 06:26:23 PM »
Probably the best idea...
He does some medication for the gout but it just flares up once in a while.
Yeah, that would have been a good idea before he bought this 850 but he loves this thing so I don't see that happening.
I think that might be quite a bit of modification for the brake side.
Thanks all, I think I'll try the added on heel section.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
2013 Harley FLHTC
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
